Question about Radio Communications
How do i fix bits of static in levetron GH808U Communicator Vibrating Surround Sound Headset with Mic?
I get tiny bits of static every now and then
SOURCE: Nokia E90 Communicator - callers can hear me but I cannot hear
try to format your phone, and check if thhe problem persists.
FOR SOFT-RESET:
- at Standby Screen type-in => *#7780#
It will ask for “Restore all phone settings-phone’ll restart….”
Then it asks for security code enter factory default => 12345
FOR HARD-RESET:
- at Standby Screen type-in => *#7370#
FOR FLASHING- TOTAL RESTORE: (Do this if your phone does not boot up)
1) Remove the battery, and then wait for about 20 min or so before putting it back
2) Press and hold these three keys together -Green dial key, Star key[*], Three key [3]
3) switch ON the phone.
4) Do not let go the three keys until you see the WELCOME screen displayed and just let it complete the boot process.
check if this helps. if this doesnt help contact Nokia Care Point-> http://europe.nokia.com/A4388379
thanks for using FixYa
Posted on Mar 04, 2009
  • 11 Answers
SOURCE: My MIC, Line In and Line out sockets are occupied
A local computer store or Radio Shack should have a splitter that you can use for that. I also have speakers into those connectors and needed a splitter to also connect a headset for online game matches. Should be under $8.
Posted on Oct 05, 2009
  • 68 Answers
SOURCE: The sound from this TV is terrible both with
That kind of problem is difficult to figure out without getting into the TV, but my guess would be a problem in the tuner. It can be fixed by replacing the tuner, or the tuner board. You can verify if it's the tuner by using an input other than the RF input to the tuner to see if it clears up. Try a DVD into the component inputs.
If you use a cable box, or satelite reciever, the sound problem can also be originating there. You can rule them in or out by trying the DVD in the component input test mentioned before.
Good luck.
Posted on Nov 29, 2009
  • 18 Answers
SOURCE: x31 make static like sound...
This sounds like you have a faulty talkback cable. You probably either need to purchase a new one or talk to turtle beach support about getting a new one sent out.
Posted on Mar 11, 2010
SOURCE: how to fix mic in nokia e 90 communicator
you will have to open the phone and put a new one in it is not hard to do i hop it work
Posted on Apr 06, 2010
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
Sound
If it's in warranty, you should contact Motorola for replacement. or depending on where you bought it, you may be able to return it to the retailer/wholesaler for an exchange dependent on the laws in your state/country? It's more than likely a lemon/defective unit.
Mar 29, 2008 | Motorola Mobility H700 Wireless Headset
How to sync afterglow ax.4 headset with xbox 360
how do tou fix the after glow ax.4.the problem whith it is that my freinds can hear me but i have to un plug it to hear them
Aug 03, 2012 | Microsoft Xbox 360 Afterglow Ax.4 red...
When i move the cord on my turtle beach x1 it gives me static and the mic echos when people talk. any ideas?
I found this on the Turtle Beach website: _________________________________________
If you or other players hear echoes in Live Chat:
Does it happen if you use the Microsoft communicator? Mute the microphone on your headset. Does the echoing stop? In the Xbox Dashboard > Settings > Live, set the voice to Play Through Both and unplug the talkback-controller cable. Does the echoing stop?
Echoing can sometimes be caused by high latency ("lag") on your internet connection. This may come and go depending on how much bandwidth is being used in your area.
If your talkback-controller cable's plug gets dirty, this can also cause echoing or static. Also check the input jack on the controller and make sure no foreign objects are in there.
Read these links for more advice:
Echoing can be caused by "a poor connection between the headset and the controller." http://support.microsoft.com/kb/912493 "The most likely cause is either a plug that isn't pushed all the way in, or gunk on the plug." http://xboxelle.spaces.live.com/Blog/cns!1pUP4M-J1d781v7Ac0Ta8FDw!158.entry "If you hear echo, then... someone in the chat session... needs to clean off their metal headset plug." http://majornelson.com/archive/2005/12/25/get-rid-of-voice-echo.aspx
Nov 30, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
My MIC, Line In and Line out sockets are occupied by my surround sound system. I need to use a Mic for Skype ad have tried a USB headset but both the Windows 'Sound Recorder' and the Skype 'Sound Test...
Oct 05, 2009 | Intel Motherboard
I can barely be heard.
May not be your headset as the problem. Check you pc for mic level or plug another mic into it. If you have found this helpful or fixya, please post as such. For more help please go live
Jan 13, 2009 | Logitech ClearChat Style Headset Headset
Motorola h700
Ok here is the answer. There H700 have a small foam windscreen inside over the microphone that over time block the sound. The answer is to carefully open the unit and remove the obstruction and clean residue from the microphone and it will work like new. here is a link to pictures and instructions. http://www.geocities.com/jconkwright/H700fix.html
Apr 07, 2008 | Motorola Mobility H700 Wireless Headset
Static problem
Does it has any SQ Squelch ajustment?
Oct 14, 2007 | Chatterbox HJC-FRS Stereo Communicator (2...
Radio Communications Logo
15 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
