DATA MAX O'NEIL M CLASS MARK II RIBBON FAULT POSITION FAULT
FIX PRINTER RIBBON FAULT AND POSITION FAULT DATA MAX O'NEIL M CLASS MARK II
5 Suggested Answers
SOURCE: 4208 Datamax M Class printer Problems
Check inside the green guide (sensor) for pieces of label. That will block the sensor. If the sensor is reporting a thickness which is double (250) what you expect, then that is definitely the issue.
Posted on Jan 24, 2008
SOURCE: i have got a datamax
1)PLACE THE SENSOR IN TO THE LABEL GAP PROPERLY 2)CHECK THE SENSOR TYPE IN PRINTER(menu->media settings->sensor type) 3)PERFORM A MEDIA AUTO CALIBRATION(press and hold feed on control panel) 4)SET FACTORY DEFAULT SETTINGS
Posted on Apr 15, 2011
  • 54 Answers
SOURCE: i am printing on a data max I class, and for the
On the I class printer, there are 2 solutions to make the ribbon wrinkle correct.
On the face of the printhead, there is an adjustable sheild that you can angle for and aft of the plane of the head.
There are 2 screws on the top front edge of the shield.
Also there is an adjustable cam bar just to the right, back of the printhead mounting. There is a small adjustment cam just inside of the lower rear of the head. To adjust the inmcoming angle of the ribbon, loosen the outer screw, and turn the knurled adjustment knob. You can see it plainly by opening the head, tand looking down the ribbon path. It is on the right hand lower side.
You might also try adjusting the printhead pressure(small green knobs on the top of the head) But that will depend on how much they are already adjusted down(more pressure).
Posted on Jun 21, 2011
SOURCE: i bought a canon pro
hi there,
have you checked the connection between the printer and the computer to make sure it didn't get loosen or disconnected?
If ok, then try turning the printer off, shut down your computer, reseat the connection between your computer and the printer (both ends of the cable - or can try a different USB port on your computer), then turn the printer and the computer back on in the order described.
Posted on Jun 26, 2011
I HAV A DATAMAX I-CLASS PRINTER IT IS SAYING THAT I HAVE A RIBBON FAULT AND THE PRINTER IS THERMAL
Thermal can mean "Direct Thermal" (no ribbon) or "Thermal Transfer" (with ribbon). If you want to print using Direct Thermal labels you need to select Direct Thermal from Media Settings in the Menu accessed from the Control Panel on the front of the printer. Otherwise, the printer sensors will look for a ribbon that is not there, and you will see an error message.
Feb 16, 2015 | Datamax I-4208 Thermal Label Printer
Everest ii printhead lever out of position how do you resolve this issue
Blue lever inside the access door. The lever that allows you to remove the ribbon carrier.
John Norman
Max Optical
www.maxoptical.com
Apr 08, 2014 | Rimage Everest II Printer
Rimage Everest II printer can't be adjusted
Usually this is caused by the black index marks on the transfer roll not being indexed properly. Look at the used transfer rolls and you will see small black lines that the printer used to index the print. Either they will not be crisply printed on the transfer pointing to a bad ribbon, bad or dirty printhead. OR, the sensors are dirty that read this index mark.
John Norman
Max Optical llc.
www.maxoptical.com
Dec 11, 2013 | Rimage Everest II Printer
Ribbon fault
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
May 08, 2013 | Datamax I-CLASS DMX-I-4406 Thermal Label...
97 buick century has no data from OBD2 scanner.
The protocol is class 2 . Maybe your code reader is no good .
012 GM Class II Communications
Data Link Connector (DLC)
The data link connector (DLC) contains the following serial data links:
• Class II
• Entertainment and Comfort (E&C)
The DLC also provides a power source for the scan tool as follows:
• Unswitched voltage (B+) at DLC terminal 16 (circuit 1450)
• Ground at terminal 4 (circuit 1450) and terminal 5 (circuit 1550)
Class II Serial Data Link
The class II serial data link allows the following modules to communicate data with each other:
• Body control module (BCM)
• Electronic brake traction control module (EBTCM)
• Heater-A/C control (if equipped with RPO CJ2)
• Instrument panel cluster (IPC)
• Powertrain control module (PCM)
• Inflatable Restraint Sensing and Diagnostic Module (SDM).
The Class II serial data link allows a Scan Tool scan tool to communicate with the above modules for diagnostic and testing purposes. The Class II serial data link is located at the DLC connector terminal 2. Terminal 2 consists of the following circuits:
• Circuit 1036
• Circuit 1037
• Circuit 1128
• Circuit 1049
• Circuit 1122
• Circuit 1132
Entertainment and Comfort (E&C) Serial Data Link
The entertainment and comfort (E&C) serial data link allows a scan tool to communicate with the radio or the mobile telephone handset the remote CD player (if equipped). This communication is for diagnostic and testing purposes. The E&C serial data link is located at the DLC connector terminal 14, circuit 835.
PIN #9 goes to the air bag module .
Aug 04, 2017 | 1997 Buick Century
Is there a specific ribbon that is recommended for this printer? We purchase ribbons from Heartland & it appears that the ribbons are wound the opposite direction according to the Data Max installation...
dkrueger105: The correct ribbon for this printer have ink inside, not outside. Change it because that cause a damage in springs in ribbon dispenser. Roberto Martinez
Sep 07, 2011 | Datamax DMX-I-4208 Label Printer
I am printing on a data max I class, and for the last couple of weeks, no matter what I try, I get a wrinkle in the ribbon. which creates a void in the barcode. what do I need to do to fix i?
May 19, 2011 | Datamax I-4208 Thermal Label Printer
I have a w class data max printer and it prints the labels but very light ink on it i was told that the green wheel on the side controls that but i have tried every single level on it but still light...
Lift the print head (where the label comes out and the ribbon should be right under it)
Take a clean Q-tip and some IPA, and wipe the little black line of dots you will see inder the head. These are the thermal points on the print head and they do build up debris which moves the head away from the ribbon causing lite print.
Dec 30, 2010 | Datamax M-4208 Thermal Label Printer
27 people viewed this question
jasbo
jasbo
