Question about Vacuums
I have a dyson DC65, It is so hard to push across the carpet it almost impossible to use. Its an automatic adjustment but it really is a joke. You need to be a weight lifter to push the vacuum. Any ideas on how to make it work.
  • 97 Answers
SOURCE: dyson - can't push the vacuum
try to see if the carpet setting is to carpet. i know this machine says that its a life time belt,but i would check this just in case. best way to tell if it's working is to lay the machine on its belly with the brushes pointing up and turn on the machine to see if the brushes are turning. (be careful not to put your face directly in front, just in case something is lodged in the brush and flies out )
Posted on Jul 29, 2009
SOURCE: Smartstrand carpet makes vacuums difficult to push
The seam problem could be an installation problem. It is important to pattern match any carpet with a pattern. If the carpet is a plush carpet, the seams should not be invisible, but not unsightly. If he carpet is a frieze, the seams should be hard to find. Any variance from these norms could mean a redo of the seams by a talented carpet installer. In a large room such as yours seams will never be invisible.
Good Luck, carpetguru
Posted on Sep 19, 2010
jyackle5
  • 8197 Answers
SOURCE: I have a Dyson all-floor model (not the ball). I
Have you adjusted the brush control system. If you look at the link below page 6 will tell you how to adjust. If this is not you vacuum please give the model # of the one you have so I can help you more.
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdf
Posted on Mar 17, 2011
Sure, on the side of the machine you will have a knob, you can use this to tuirn the brushbar off and have suction only.
Posted on Mar 22, 2011
  • 5370 Answers
SOURCE: The vacuum has worked fine
The 'automatic' height adjustment consists of front wheels on a swivel mechanism that is forced up or down according to how high or low you are holding the vacuum. So, if you are holding the vacuum at a height for normal operation by it's very design it will be forced into the carpet too deeply which the belt cannot handle, thus breaking it in record time. "The only way I was able to rectify this was by shoving a piece of cardboard under the wheels at an ideal height that would still pick up dirt but not bear down onto to the carpet!"------- ------ In some cases the belt breaks and brush stops working.So inspect the belt and brush too.Sometimes its the broken belt or stuck-up brush problem causing this.--------- It's usually the belt that causes the brush to stop . What happens is, over time the belt will get hot, which causes the belt to stretch. Once the belt stretches out, it becomes too long, and will stop the brush from spinning when it feels any resistance to the brushes. This is most likely why the brush is stopping when you put it down on the carpet.---------- Getting this possibilities checked will help.Thanks.Helpmech.
Posted on Aug 20, 2011
Reading this blog. Dyson is of little to no help. How disappointing when you spend a small fortune on one of their products. I'm just now experiencing hard to push with. DC25 Animal. Can't adjust height....
sorry to say your dyson is not the fault, its your carpet, a lot of new carpets have a tight weave pattern, this makes it impossible to push any vacuum. all new carpets have a directional pile always vacuum with the pile. The best option is to buy a auto drive kirby it does all he hard work for you. you can pick a refurbished one up for around 300
Aug 12, 2017 | Dyson Vacuums
Tip
Dyson DC41, DC43, DC65 or DC66 - Removing a blockage from the cleaner head or...
If your Dyson DC41, DC43, DC65 or DC66 upright vacuum cleaner doesn't seem to be picking up as well as it should be from carpets or hard floors, this may be due to a blockage. A blockage could occur if an item too big for the machine has been accidentally vacuumed up.
After turning off and unplugging the machine, please follow the steps shown in the video to locate and remove any obstructions from the cleaner head, internal hose or changeover valve.
on Jun 04, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
Hard to push across carpet
Check the belt that drive the brush not broken or brush not clogged up.
Oct 01, 2016 | Dyson DC28 Animal Upright Vacuum New DC 28...
Why is it such hard work to hoover the carpet with the dyson dc 33.it is really hard just pushing it across a new carpet.
Are your belts working and is your power head set too low? Try raising it up one or two clicks. A broken belt will not let your brushes spin and a spinning brush will help it go on carpets.
Aug 20, 2016 | Dyson Vacuums
What can i do to get my dyson to work on thick carpet not happy
Hi there, it's Jack at Dyson.
DC41 is engineered and tested to work across a wide range of hard and carpeted floor types. The soleplate adjusts automatically for optimum performance, and the brush bar can be switched off to protected hard floors, delicate rugs or long pile carpet.
We're keen to take some additional details about your DC41 and the particular carpeting you're having difficulty with - we may have some suggestions that will help. We'll also check your particular DC41 is working as well as it should be.
When you have your DC41 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 16, 2015 | Dyson DC41
I just bought a brand new Dyson DC28 and
If you can, check the latest Consumer Reports buying guide for guidance.
Sep 11, 2012 | Dyson DC28 Animal Airmuscle Vacuum Cleaner
Dyson 33 wont push on plush carpet
I'm sorry to hear you're having difficulty using your DC33 on this particular carpet. If you haven't already contacted our Helpline, I'd encourage you to do so, as we'll be able to discuss other options which may be more suitable for your needs.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 27, 2012 | Dyson DC33 Bagged Upright Vacuum
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
700 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
