Question about Health & Beauty
Nueroma of the foot - Health & Beauty
Is there a larger foot rest or a way to lower and extend foot rest
Foot rest? Are you referring to the foot control unit or a presser foot? If it is presser foot, most likely you do not have the correct presser foot for your machine. Search the internet for the "make model presser foot" (substitute make & model with your machine make & model). There are basically 3 presser foot styles--low, high & slant. They are not interchangeable.
If you are talking about the foot control, sometimes you can find other foot control units for your machine, possibly even generic units.
Dec 28, 2016 | Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
Turn 675 squared feet into room dimentions
You can devide it up how you want. 675 squar feet is like having 675 one foot by one foot squars so a room that is 10 foot in one direction and 10 foot in another is 100 square feet so 6 of those would be 600 square feet and say a room that was 7.5 foot by 10 foot would be 75 foot
Feb 14, 2015 | Office Equipment & Supplies
What are the torque specs for the head bolts on my 2001 V92C?
10mm nuts are 40 foot pounds. 8mm nuts are 18 foot pounds. You need to torque all the nuts to 10 foot pounds to start, then torque the 10mm nuts to 20 foot pounds, then 30 foot pounds, and then 40 foot pounds. Retorque all the 10 mm nuts to 40 foot pounds and then retorque the 8mm nuts to 18 foot pounds. Torque the bolts in a criss-cross pattern.
Oct 27, 2013 | Victory V92 Cruiser Motorcycles
How do I attach the darning foot on a Pfaff Expressions 2.0 please?
on the machine, there is a foot holder attached to the machine, & the feet to the machine will either be snapped on to the foot holder or there is a screw to undo. most of the new machine are snap on feet, take the presser bar lever up, there is a little lever on the back of the foot holder, & you push it toward the foot holder bar & it will release the foot & you put the other foot down on the needle plate & bring the foot holder bar down on the foot until it snaps on to the foot
May 04, 2012 | Sewing Machines
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
Something happened to my janome 6600 I drop the A foot to changes it to the zipper foot but now it does not grab any foot
Could you be a little more specific about not grabbing any foot? Do you mean if you use a button hole foot, sequin foot, open toe foot that none of them work?
Sep 01, 2011 | Janome Sewing Machines
How to sew buttonholes
First thing you'll need to do is switch the presser foot.
Your machine should have come with a specific button hole foot.
(might have an R on the bottom)
To snap off:
Raise the needle and presser foot.
Press the red button on the back of the foot holder
and the foot will drop.
To snap on:
Place the presser foot so the pin on the foot lies just
under the groove of the foot holder.
Lower the foot holder to lock the foot in place.
Select which buttonhole style you would like to stitch.
This can be done by selecting a mode (buttonholes are 06-08)
and then adjusting to the desired length and width.
After you do this, lower the presser foot and hold the foot pedal down.
The machine will automatically sew the buttonhole and stop when it is finished
All you'll need to do is just cut the thread after.
Hope you found this information helpful.
Mar 17, 2011 | Janome DC3050 Computerized Sewing Machine
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
