Question about Singer Sewing Machines
How do I change a light bulb in a singer 4228
  • 323 Answers
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Posted on Apr 11, 2009
bargainbox
  • 1388 Answers
SOURCE: Singer Inspiration 4228 issues..
If you have a new machine, it is likely in panic, you have altered the tension and need to go back, so although much of this is to do with cleaning, it will help generally now, and later when you need a refresher....
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 31, 2009
  • 980 Answers
SOURCE: I have a singer inspiration 4228. When I tried to
If you have pushed the winder over and it is not turning either the winder rubber has worn down one side, or there is residue on the winder rubber, or the bwinder has seized through lack of oil which is quite common, with the winder in the off position see if you can spin it by hand, if you can't then chances are it has seized, put some WD40 oil on the top of the spindle and leave it overnight, then put an electric drill over the top of the spindle and switch on slowly, that usually works.
Posted on Mar 07, 2010
  • 1788 Answers
SOURCE: my singer 4228 needle keeps hitting the round
Did you have it apart for cleaning and maybe it is not seated right? I asked a repairman, and he said most of the time it is that the needle is not inserted right, or above problem Other than that your timing may be messed up and you need a professional to look at it.
Posted on Oct 06, 2010
SOURCE: can't find straight stitch setting on singer inspiration model 4228
do you have a manual? if not
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4228) & click search
Posted on Apr 24, 2012
How do you change bulb on singer curvy 8763? Nothing in manual, nothing online. Can it be replaced? Seems to be soldered in or something and no replacement listed either.
The Singer Curvy 8763 bulbs are LED bulbs so they should last for 100,000 hours (or probably the life of the sewing machine). Thus the bulbs aren't meant to be user replaceable. Unfortunately, even though the bulbs should last for years, Singer only provides a one year warranty on them. Thus if your machine doesn't have working lights and isn't still in that first year, you'll have to pay for the repair.
I hope this helps and wish I had better news for you if there is a problem with the lighting of your sewing machine.
Nov 16, 2015 | Singer Sewing Machines
How do you change light bulb on Singer 7444 portable sewing machine?
Instructions regarding changing the light bulb are in your user's manual. If you don't have it, you can download a .pdf copy free from the Singer site, and here's the link. Instruction Manuals
Jul 11, 2014 | Singer 7444 Mechanical Sewing Machine
Singer 4228 bobbin case
try youtube for a video,, type in singer 4228 bobbin case
Apr 27, 2012 | Singer Inspiration 4228 Mechanical Sewing...
Can't find straight stitch setting on singer inspiration model 4228
Go to the home page
Apr 23, 2012 | Singer Inspiration 4228 Mechanical Sewing...
How to set the machine to straight stitch
Go to the home page
I have a Singer Advance 7422 Sewing machine. The light bulb went out. How do I change it and where can I find a replacement bulb?
My light went out of my Singer advance 7422. Does anyone know how to change it or where to buy the bulb? Thank you for your help.
Jun 05, 2011 | Singer 7422
My singer 4228 needle keeps hitting the round metal shank that turns in the machine
Oct 05, 2010 | Singer Inspiration 4228 Mechanical Sewing...
Inspiration 4228; can't raise bobbin thread.
Change the needle, make sure it is the correct way round, failing that email me and I will attach timing instructions.
Ken
Aug 11, 2010 | Singer Inspiration 4228 Mechanical Sewing...
sewman7
Apr 11, 2009 | Singer Sewing Machines
Sewing Machines Logo
103 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
