Question about Kenmore Elite 45986 Front Load Washer
WATER IS LEAKING OUT THE FRONT - Kenmore Elite 45986 Front Load Washer
  • 6,784 Answers
Hi, if its leaking directly from the door or, bottom section of the door, replace the door seal asap. it has been compromised.
Check for any jammed pieces of plastic or, coins that may end up stuck in between the door and front panel.
Now, if its coming from the bottom of the unit, check all drain hoses and, the inlet hose assembly as well.
Posted on Jun 22, 2009
Leaking water from front of door. Replaced boot seal but still leaking. It looks like door is kicked out at the bottom. Would replacing the hinges help?
Try turning the water pressure down. If you have high water pressure the water comes into the dispenser to hard and splashes over the front & side of the dispenser draw the trickles down the inside of the front panel out on to the floor. Very common front loader problem.
Aug 06, 2015 | LG WM0642H Front Load
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Headlight washer system leaks out all the fluid just sitting without using the pump button
first check where it's leaking from, if water dropping near front wheel it's leaking from tank first check the rubber grommet for both washer motor 1 wiper washer motor and 2 head light washer motor, both are in the water tank, if your car water dropping from front end under the front bumper it should leaking from washer nozzle in this case need to replace the head light washer nozzle. some time leaking from hose if you check from underneath you can see where it's leaking from,
Nov 20, 2010 | 2000 Mercedes-Benz S-Class
My 2006 charger 3.5 is leaking coolant but only somtimes is it a sign of water pump malfunction no indications on the gauges but car seems to be running hot
this is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
Feb 04, 2010 | 2006 Dodge Charger
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
Jul 14, 2009 | LG WM2688H Front Load Washer
Water leaking on the floor while filling
Open the back of the washer. Start the fill cycle and observe where the water is leaking from. You are not going to get a full view of the entire tub by only opening the lower front access.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Sep 11, 2007 | Whirlpool WTW6400SW Cabrio Washer
Kenmore Elite 45986 Front Load Washer Logo
167 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
