Question about Panasonic As 300NN A Commercial Grade Electric Stapler with Adjustable Margin and Status Light
I need to buy staples for the panasonic as-300nn-a
The 1/4" staples i bought are too large (?) For my new TR110. Am i doing something wrong or do i need to buy a smaller size?
You are probably buying the wrong staples for your unit. Check the instructions for the type of staples it uses or make sure the staple package states they are compatible with your unit..
Jan 06, 2017 | Tools & Hardware - Others
The spring that loads the staples for stapling broke in half where can I buy a new or used one
  1. Panasonic AS-300NN-A Panasonic Commercial Electric ...
    electricandbatteryofficestaplers.julietshop.tk/panasonic-as-300nn-a-panas...Mar 19, 2015 - Commercial-grade electric stapler with 25-sheet capacity features jam-free operation, auto-reverse, adjustable stapling position and LED status ...
Jul 11, 2015 | Panasonic As 300NN A Commercial Grade...
How do I open the staple compartment? Already tried the back button
Pushing the button should eject the staple compartment from the front of the unit. It sounds as if the stapler compartment is jammed or corroded.
While pushing the button, attempt to pull the compartment from the front of the stapler. It should slide out like a drawer. Try pulling on the front of the compartment while applying a little pressure in different directions.
You may have to use a small tool to grab the compartment if you can't get a good grip. You may have to use some force. Use only as much pressure as you're comfortable with.
When you do open the compartment, inspect all moving parts and bearing points to be sure nothing is jammed, bent, corroded or seeing excess wear. Remove a jam with small pliers, being sure to get the entire staple. Use fine sand paper on corrosion and then treat with a bit of oil.
Sep 08, 2011 | Panasonic As 300NN A Commercial Grade...
I need a replacement film for my KXFP1o1 plain paper fax machine. Is this film still available? The machine is 12 years old, but works very well.
You should still be able to purchase this film. You need panasonic film part # KXFA65. I'm not sure where you live but if you are in Canada or the USA check Staples, BestBuy or Office Depot. I know Office Depot stocks them and they cost about $36 and should yield 330 pages. You can also buy them online from places like eBay for a price range of $12-$30.
Regards, Chris
Aug 23, 2011 | Panasonic KX-FP101 Plain Paper Thermal Fax
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
AS 300 electric stapler--pulled out jammed staples but even though it staples, it won't grab the staples (staples as though empty)
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Sep 28, 2008 | Panasonic Office Equipment & Supplies
Panasonic DP-8045
it means that your finisher staple motor jammed. try to remove the staple cartridge and anything that might make the staple not to move.
Aug 20, 2008 | Panasonic DP-8045 Grayscale Copier
Panasonic As 300NN A Commercial Grade Electric Stapler with Adjustable Margin and Status Light Logo
43 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
