Question about Maytag MSD2454G Side by Side Refrigerator
May maytag refrigerator water dis dose not have cold water it is luke warm modle p5wb12nl/p4rfwb12 how do i get the water colder
bestdarngood
  • 3037 Answers
SOURCE: Fridge too warm: makes ice, does'nt dispense it: dispenses water warm
I know that it is new but this might be your problem
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Since it is new, you should have a warranty and I would see if a repairman can check it free of charge before attempting anything, I don't know your skill level with this type of machine but good luck and don't forget to rate this post, Have a Great Day!
Posted on Mar 23, 2008
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Maytag model MZD2766GEB: Freezer compartment seems
I believe your Adaptive Defrost Control found inside the fresh food compartment and behind the control panel is failing you. The part number is 61005988 If not this the defrost heater and defrost thermostat may be the next likely cause. Thanks, Sea Breeze
Posted on Aug 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Maytag digital panel click on, then off. Refrigerator is warm.
The fault may have three places that it could come from. The Digital Logic Panel itself the motherboard or the low voltage transformer. If you like I will help you, Let me know, Thanks, Sea Breeze
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: refrigerator warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
Refrigerator warming (50 deg) while Freezer Temp OK or Colder than normal
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Maytag modle #rsw24eod is getting ice inside refrigerator
If the thermostat will not warm the temperature or if you have the vents or damper adjusted to there correct position I would lean to your thermostat being defective and stuck on a colder setting than you want.
Part 61001673 Temperature Control. Let me know if you are able to adjust the temperature or able to move the damper position to allow less cold air from freezer to the fresh food compartment. Sea Breeze
Aug 21, 2009 | Refrigerators
I have a two year old american standerd singel handel faucet Two
Yes, change the cartridge, it sounds like the cold is bleeding into the hot.
Jun 03, 2009 | Oceana 009009022 Udermount Kitchen Sink-...
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Rinnai tankless water heater
where the pipes are laid out it may run along an outer wall and the cold weather is cooling the water before it gets to the shower try to track the pipe from your water heater to your shower and insulate it where it is coldest
Dec 11, 2008 | Water Heaters
Maytag MSD2454G Side by Side Refrigerator Logo
126 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
