Question about Hoover UH70040W Bagless Upright Cyclonic Vacuum
V belt replacement
I tried replacing v belt part #38528034 - too loose - it matches belt I took off to replace which also was loose. What am I doing wrong
2 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: BELT TO THE BRUSH SEEMS TOO LOOSE EVEN WHEN REPLACED
Hoover U6437-900 U6439-900 Upright
LOOSE BELT. THE BELT IS STILL LOOSE EVEN AFTER REPLACING
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The reason it seems like the belt is too big is probable correct, you may have the wrong size belt for your vacuum, use genuine belts – your particular model is a self propelled model and takes two (2) belts and they should stretch on very tightly and snug and it is smart to use the genuine belt package for the model that you have and we Recommended the belt change for flat belt(s) are 4 to 6 months for better cleaning
They should be tight on the belt pulleys in order to do the best cleaning – use genuine belts
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Posted on Apr 15, 2008
Hoover Windtunnel model U6485200B troubleshooting brush not spinning
Hi! The brush-roll feature needs to be engaged for the belt to tighten, so when checking the belt it will appear to be loose. Be sure you have replaced both belts on the vacuum with genuine Hoover parts. This unit takes belt 38528034 and 38528035. Also, make sure the vacuum is on carpet mode. Follow the link to view the instruction manual which provides instructions and illustrations on changing the belt to be sure it is assembled properly.
http://hoover.com/file/509/
Hope this helps!
Aug 08, 2014 | Hoover Vacuums
Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum what belt # do I need both belt # please
The wider belt is # 38528035,( package # 40201170 ), and the v-belt is # 38528034, ( package # 40201200 ). The wide belt should be replaced twice as often as the v-belt.
Jul 06, 2011 | Hoover Ultra U6430-900 WindTunnel Bagged...
Can not find a proper fitting v-belt to fit my hoover wind tunnel cyclonic. i even ordered it from hoover.
The correct belt is # 38528034 ( package # 40201200 ) This belt may seem loose when it is installed, because there is an "idler bearing" that pushes down on it when the handle is released and dropped back.
Mar 07, 2011 | Hoover U5780-900 Windtunnel Cyclonic...
Belt broke, there are 2 belts the wider one broke & I can not get it on. The thin belt I got on OK. What do I do?
Greetings,
We have recorded a ver convenient video on how to replace the belts on your Hoover Windtunnel Self-Propelled Upright Vacuum Cleaner. We also explain how to do regular maintenance on the roller brush to prolong the life of these belts. It's best to replace both the thin belt, and the fat belt, Parts 38528034 and 38528035 at the same time.
Here's our video repair;
I hope that this helped you. If this helped, please be sure to rate the repair as helpful by clicking on the Thumbs Up Icon in the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 22, 2010 | Hoover U6434-900 Bagged Upright Vacuum
The V belt is too loose. The brush switch
Did you purchase the exact replacement belt for the vacuum, or did you buy one to match the one you have?
It sounds like you have the wrong belt, but, it could be the roller brush is not properly installed or the roller has worn down significantly.
Dec 18, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
How do I replace the drive belt in the hoover u6401?
Remove the plate from the vacuum's underside. You will see fourscrews or two clips that attach the plate to the vacuum. Removingthe plate will give you access to where the belts are running. Remove the old belts and replace with new belts. The hoover self-propelled models use two different belts. One is a flat belt Hoover #38528035 and the other is a V belt Hoover #38528034. You can find these belts at www.vacbelts.com on these pages:
http://www.vacbelts.com/hoover-38528035-belt.htm
http://www.vacbelts.com/hoover-38528034-belt.htm
Oct 14, 2009 | Hoover Vacuums
My Hoover U6439-900 also losing belts
When upside down there is no resistance,on carpet there is.
You need to try a a fresh, genuine hoover belt and buy a spare, belts stretch and slip after 30 -90 a days of normal use, often to 25-30% oversize Hoover belts generally fit very snug. If your belt looks shiny inside, that is likely the issue. Try that and post results
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel
If this is new, you have a years warranty on it, take it for repair. Did you get the right belts, the numbers are 38528035 for the flat belt and 38528034 for the V belt. Also if you are catching something like a towel or area rug in the brush roll, it will knock of the belt. Is the brush roll turning freely. If not then it needs to be replaced, does it motor sound ok? If not then there is a problem with it.
Mar 09, 2008 | Vacuums
Vacuum belts
Take off the bottom plate, there are 2 belts, the V belt (38528034)goes on first, it goes around the pulley then around the brush roll. The Flat belt(38528035), put it around the motor shaft first, then stretch it to go over the bigger pulley.
Mar 06, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing belts
Turn vac over, remove the 4 screws holding the bottom plate covering the brush roll. There are 2 belts, one is a V belt ( 38528034) for the brush roll, the other is a flat belt (38528035) that goes from the larger pulley and the motor shat, put it on the motor shaft then stretch it to go over the pulley.
Jan 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover UH70040W Bagless Upright Cyclonic Vacuum Logo
19 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
