Question about Miele S548 Bagged Canister Vacuum
The unit won't turn on - I'm not finding a reset
The cord rewind works, but I didn't find a reset in the manual or on the machine. It worked just a few days ago.
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Motor shut off
Try it half an hour later, does it run? If so it's overheating. Change your filters and empty the cup.
If it does not run it's likely a problem with the cord rewind. Some of those units had a recall on the cord rewind. To find out for sure find a local hoover service center and take it in for repair many times at no cost.
Feb 10, 2013 | Hoover Elite Rewind Pet Bagless Upright,...
Power head attachment works great when plugged into the hose part of the vacuum. The problem is when I attach it to the tube for normal use there is no power. I have checked all the connections and...
try having someone turn the machine on and off while you pull the cord in and out with the cord more angled towards the on/off switch. Sometimes these models have a break in the cord rewind and will not put the power through to the motor.
Keep in mind this is repairable, and if the unit is less than 5 years old it should still be under warranty.
Good luck .
Nov 19, 2010 | Miele Vacuums
Think cleaning lady pulled too hard on cord...now no power, doesn't turn on
it is possible that the cord rewinder has become broken inside the unit. It is a common problem with this and other models by Miele.
There IS a fix to the cord rewind, unless your model falls within the 5 year warranty. In which case contact your nearest Miele dealer for a replacement to the cord rewinder.
Good luck.
Nov 19, 2010 | Miele S514 Solaris Electro Plus Vacuum
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Cord rewinder on a Electrolux model C102J vacum cleaner
Hi there Johnd, SmartAlec from Nelsonvacuums.com.au here. I fix vacuums full time for a living and the first time i had this problem with the australian version of this vacuum it tok me an hour to pull it apart and back together. now i have done a dozen or so it is about a 30minute operation. I dont know what you rate your technical skill level at but i give this machine a 8/10 for hardness. It is most likely that the cord has jumped off the reel and is wedged so it shouldn't require parts but it cant be done without nearly stripping it down. There is no reset or similar for the reel. My advice unless your very confident take it to a repairer. It would be 1/2 - 1hr of labour charge only i would think.
Hope this helps.
SmartAlec
Sep 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Auto rewind for the electrolux oxygen 3 ultra
HI
If this isnt working correctly, take it back. It wont get better
Feb 20, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The roller brush will not stay on-& the cord rewind is stuck on
There is a reset on the power head, does the wand fit tight in the neck of the power head, if not you may have a problem there, either the wand or the neck. If the lever is stuck on, then it is jammed or broke, maybe a spring is out of place, in any event the canister will have to be taken apart to see what the problem is.
Feb 19, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Miele S548 Bagged Canister Vacuum Logo
48 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
