Avanti wd31ec had a power surge is there fuse that need to be replaced? Or some other parts to get it working again?
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on May 09, 2014
Need user manual for Sonya compact dryer
Hi, could not find a users manual for sonya SYD-60E dryer so that I could order a thermal fuse, as the dryer would not run, however, I found a blog that suggested that Avanti, Sonja and Panda were made by the same manufacturer, I found a phone number for Avanti, ordered the thermal fuse for the only model that Avanti sells, which cost $10.00, and in about 10 business days the part arrived, we installed it in our Sonya dryer and our dryer works beautifully! Hope this helps
May 24, 2016 | Dryers
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
I have a problem with the power supply board with my TV (Samsung LN46A750). I had a fuse blown and tried to replace it (with a like fuse, of course). Replacing that fuse and attaching the power cord let...
Power supply board have power surge parts,but not totally dead,it just giving to much power some where,that why it keep killing ur fuse.This problems,u must have great electronic skills to track it down.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Power surges are rarely happen,but the surge protector will stop massive power will go the protector when it happen instead all the power will go to the tv itself.
Mar 16, 2011 | Samsung Televison & Video
Avanti EWC16B (wine cooler) got fried by power surge
A lot of time during storms the control boards in appliances get messed up. Try unplugging it and plugging it back in after about 20 seconds. A lot of times that will reset the controls.....if they did not get fried.
Sep 12, 2009 | Refrigerators
Avanti microwave. Panel not working, alot of beeping.
sounds like a panel issue for sure.
if the microwave is over 5 yrs old I would recommend replacing it
newer microwaves use far less power than before.
and they are not too expensive
May 27, 2009 | Avanti MO7180TW 700 Watts Microwave Oven
Hitachi 50GX30B 50 in. Rear Projection...tv won't turn on since electricity went off & on
I have worked on several of this model for power surge damage. Usually what I find is a blown fuse, a shorted regulator i.c. and possibly a blown bridge rectifier(diode array). On rare occasions you can solve this problem by replacing only the fuse, but if the fuse blows when you plug the set in, you will more than likely find above mentioned parts have failed. The best thing to do is to call a repairman but if you have an ohm meter you can test it yourself:1.Unplug set and remove rear cover.2.Get spotlight and look closely at where power cord connects to circuit board.Small glass fuse will appear black if open usually.Otherwise,test for continuity, or just replace it.3.After replacing fuse plug power cord back in while looking at fuse.If you see an instant flash, fuse blew again meaning you will need to obtain parts in power supply and solder work will be required. That is probably as far as I can take this other than saying that you might first want to look at underside of circuit board to determine if major surge damage has occurred. If it has you will immediately know because it will have burn marks all around a/c power supply. I hope this helps, Russmann.
Apr 28, 2009 | Hitachi 50GX30B 50". Rear Projection...
No power at the power panel( Aqualink RS8)
if unit comes on write down all auxs then remove plugs replace fuse turn on then plug one in at a time till it blows then you know which auw then see if wires are burnt
Apr 25, 2009 | Jandy AQUALINK RS TELELINK KIT
Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Feb 19, 2009 | Avanti DER24CSS-1 Electric Kitchen Range
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
