Question about Wahl 9855-300 Groomsman Pro All-in-one Rechargeable Grooming Kit,
Assembling the small blade back together from scratch?
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
Assembly issue
You mean the knob is connected directly to the blades? I'm not sure what you mean by blade knob, but does turning it turn the blades? If so, I'd suggest wedging something between the front grill and the blade to prevent it spinning and try to twist the knob off. I tried to find a owner's manual for your fan, with the assumption that there would be assembly instructions, but was unable to find one. Do you still have the owner's manual? And if so, are there any assembly instructions in there? How did the back grill come off, if you can't get it over the knob? Or are you assembling it for the first time. If you are assembling it for the first time, was the knob there when you got it? That seems poor design if so.
Sep 03, 2007 | Honeywell HS1750 Stand (Pedestal) Fan
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
Saniflo permanently on,
If the blade and impeller spin freely by hand after removing the obstruction but does not pump out the waste after assembling the unit back together, then could be a bad capacitor, since the capacitor spins the blade and impeller. If the capacitor goes bad then it will just make a humming noise and not pump the waste out.
May 20, 2010 | Saniflo & Saniplus& Macerator Pump
I want to take apart the front suspension on my 1973 dodge challenger . I'm looking for a diagram showing the complete front suspension parts .So I don't get lost putting it back together later and a parts...
You might be better off with a digital camera, and take your own pictures of the areas that you think may cause you to scratch your head later when re-assembling. Once on your computer, you can zoom or whatever as needed. If that's not an option, get back to me/us, and we'll dig a little harder and see what we can find.
Dec 05, 2009 | Dodge Challenger Cars & Trucks
Help about assembling my trimmer
I had recently put together one that may or may not be the same - the head seperated from the body, and a small spring loaded detent inserts in the backside that "locks" the head at steadily increasing disances (lengths). The hardest part to assemble is the switch: which the outer slider is installed first, then the switch assembly (w/Small printed circuit board ) is slid very deeply into the plastic body of the shaver - you'll see where it locks into place. Then the lower circuit board and prongs attach at the bottom (also you can see where it locks in). Lastly, the battery is installed within its' holder and snaps into the plastic case. The two pars of the cases are then mated and click-lock into place (Think there's a single phillip's screw to keep it locked). Lastly, the blade cover snaps into place from the top, and you should be good to go - I never got to take it apart, but I had to put it back together...I believe that's how it goes, and mine works - there is no allowance for error, and it looks to me that if it's not 100% right it won't go together anyhow - good luck...
Jul 07, 2009 | Wahl 9916-800 Groomsman Beard Trimmer
How do I put my shaver back together after I replaced the blades?
For Remington clippers, the smaller blade has a groove which matches a beveled edge on the trimmer body. Line it up, align the larger blade to its screw holes, insert and fasten screws until tight, and you're good to go. Oh yeah, and try to center the small blade.
Mar 12, 2009 | Health & Beauty
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Wahl 9855-300 Groomsman Pro All-in-one Rechargeable Grooming Kit, Logo
94 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
