LTF2940FS1 front loading washer not filling with water
2 Suggested Answers
TampaNative
  • 778 Answers
SOURCE: My FWT645RHSO front load washer
Hello Twisted1,
If you have adjusted the level to reset and then to where you want it and it still won't fill to the level you want, I would suspect the level sensor in the washer itself. Most washers have to be switched to reset before setting a lower or higher water level. I hope it's as simple as the reset level switch for you.
Good Luck.
Posted on Feb 28, 2008
I have a frigid site affinity front loading tumble action washer. The water comes in but does not fill. Window in front shows no water accumulation. Otherwise it is functioning. The drain hose is 11 inches...
Not sure if this your first front load or not. A front load washer does typically fill up in to the window. Front load machines use a lot less water than a top loading machine.
Aug 14, 2014 | Washing Machines
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
FRIGIDAIRE LTF2940FS1 Error Code "PAU"
Hi
PAU is short for pause; the machine detected something wrong so it paused itself. Unplug it from the wall for a minute and plug it back in, it may reset. Once you plug it back in, it should display a Numerical code. You need to find out what's that error code mean.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Feb 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
