Question about Homelite 'Yard Broom' Leaf Blower
My home lite yard broom blower has a vibration at hi rpm
Runs fine but i am afraid i am going to blow it up
    Problem Solver:
  • 14 Answers
I'm not sure if I have an answer, but I had one that had a broken impeller on the pick-up fan. You can check this by removing the shroud in front of the pick-up fan on the bottom of the blower and check that all of the impeller's are the same size.
Posted on Jun 22, 2009
My homelite yard broom is hard to start and stay running
check the scrren inside the carb to see if it is ditry or needs replacing.
Jul 16, 2012 | Homelite 'Yard Broom' Leaf Blower
I have a Homelite YARD BROOM II 170 mph Blower.what is the oil to gas ratio?
I usually mix at 50:1 useing klotz two stroke oil,or 44:1,klotz is high performance zynthetic oil,also has nice sweet smell when running,keeps the neighbors from complaints on bad smell.
Feb 11, 2011 | Homelite 'Yard Broom' Leaf Blower
What kind of oil do I mix with gas for my homelite mighty lite bv blower
2 cycle oil
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 08, 2010 | Homelite 'Yard Broom' Leaf Blower
I have a homelite yardvark blower and I want to change the fuel filter. How do I change the fuel filter? Yardvark runs fine at beginning, but begins to run eradicatly after a short time. What's the...
could be fuel lines, fuel filter, or your carburetor needs to be rebuilt. The carb has thin rubber diaphragms that get hard over time, hot weather, or stale gas. Need more assistance,
email desertairrepair@aol.com.
Jan 31, 2010 | Homelite 'Yard Broom' Leaf Blower
My leaf blower only runs on idle only when choke is close. i clean the carb. 2 times and i replace the muffler
I have found that most of the homelite hand blowers have a tendancy to loosten the cylinder bolts, that causes a low vaccuum situation thru the carb and needing more fuel to run. I would recommend you completely dissassemble the engine and replace the cylinder gasket, Use the blue loc tight on all the bolts. Any of these engines that dont have a thru crankshaft to dispurse the vibration, tend to vibrate all the bolts loose.
Nov 01, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 2 yard broom 170
You have found the HI and LOW settings. The idle wouls be set by starting and warming the unit up. After warm up, take your screwdriver and turn the LOW screw OUT until the engine starts to lose RPM's. Turn the screw IN until it starts to lose RPM's. Once you have those two points, back the screw about halfway between. You can do the same for the HI setting if you need to. Good luck...Lee
Aug 23, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas only or add mix?
mix!!! regular gas will ruin it
May 17, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
122 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
