Question about Acer Aspire 5050-3242 Notebook
Belkin N router reads everything but the computer.
Router just stopped working. I'm hooked directly into cable modem from computer. When the patch cable is hooked from the route to modem all lights are go except for the computer light (icon). Belkin tech keeps repeating for me to switch the wireless on - But where's the switch?! What are they talking about?
  • hdsigman Jun 23, 2009
    I'm afraid I've done that ad infinitum: No luck. The lights on the new Belkin N router stay solid blue when they're functioning, and there are four alight when things are humming along properly. So, sorry, no cigar for this solution.
  • 244 Answers
If your router was working before, and suddenly stopped working, then you probably need to reset it.
Unplug the router from power, also unplug all network cables from it.
Wait about 30 seconds.
Plug power back in, followed by network cables.
Wait some more seconds while the router restarts.
Only the Power light and the Status light should be solid.
All others in use must be blinking, which means they are in use.
Try connecting to the internet with cable first, then try wireless.
It should work.
Please don't forget to rate if answer is helpful
Posted on Jun 22, 2009
My router does'nt read the modem, it never stop boothing!
Remove ALL cables, verify connections , connect cables, Unplug the Modem, remove battery, unplug the Belkin. Install battery in Modem and plug in, let it run a selftest, when finished, plug in Belkin allow it to selftest. Reboot computers.
Dec 12, 2012 | Belkin F5D8236-4 Router
IWon't hook up to my modem
Try getting a different CAT5 cable.
Mar 20, 2010 | Belkin F5D7234-4 Router
Can not connect Xbox and computer to be online at the same time
is this a new belkin router... I suspect that the belkin has a firewall. or the windows box is trying to take the XBOX over...I am sure we can get through this
Aug 05, 2009 | Dynex Enhanced-G Wireless Broadband Router
Belkin F5D7230-4 not working anymore?
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Router will not connect to internet
You will need to assign a different ip address to the modem - Iam assuming that both the router & modem are using the same ipaddress 192.168.1.1? If that is the case, then assign 192.168.1.2 tothe modem.
Mar 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
I have two computers that I want to share my cable internet connection. When connected directly to the modem the first computer conects to teh internet fine. But when I connect the computer to my Belkin...
Perhaps one of your ethernet cables is bad?
When everything is connected, the "WAN" light on your router should go on, as well as the lights for whatever network connections your are using for your computer.
Obviously the cable that you used to connect your computer directly to the modem is working, so try replacing the other one.
Sep 05, 2008 | Belkin Computers & Internet
Trying to hook up belkin wireless router to cable modem and don't know how the hook-up should be
If you have your pc connected directly to your broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Aug 09, 2008 | Belkin Computers & Internet
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
Acer Aspire 5050-3242 Notebook Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
