Question about Sharp XE-A23S Cash Register
Receipt off on set up - Sharp XE-A23S Cash Register
Receipt
This is very strange. Are you referring to the receipt printing or reports?
Do you have the receipt set to print on every sale, or just when you press the receipt button?
Aug 01, 2012 | Casio Parts Cash Register PC Desktop
How can i request a receipt for my yahoo mail
Not in Yahoo Free Accounts.
However
Yahoo Mail Plus is what gives you use of capabilities to collect or send emails through
use of email clients.
You do it through POP account. Like through Outlook or other email client.
In My own Outlook to set it up. Go to Tools > Receipts Tab > Requesting Read Receipts
> (Check) Request a receipt for all sent messages. > Returning Read Receipts > Always
Send Read Receipt > Apply > Ok.
Jul 10, 2011 | Yahoo Mail
How do I set automatic fax receipt?
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Automatic paper adjustment
Goto File, Page Set Up, Margins.
Be sure "Marigns" is in the "Inches" setting.
Enter 3.0 inch in two boxes; Topp, & Bottom.
Good Luck,
Aug 04, 2009 | Epson LQ 580 Matrix Printer
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
My credit card receipts do not cut between the portion that the customer must sign, and the sales receipt portion. I'm forced to cut it manually. Has anyone else had this problem? Is there an option to...
In windows you have to set the printer to receipt printer and where you want it to cut the tape also check under setup or settings in pc charge then printers and then receipt printer there are functions you can change there as well.
www.greenlightpayments.com
Jul 18, 2009 | VeriFone PCCharge Pro Full Version for PC
SMS text receipts
In Nokia you can turn off receipts. You may need to get the manual out, but you do not have to have receipts, obviously a little money making scheme, like my voicemail access msgs costs me everytime!!!
Apr 25, 2009 | Palm Treo 680 Smartphone
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Sharp XE-A23S Cash Register Logo
54 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
