Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fire started in freezer after I washed it out.
AFter washing out my freezer,yes it was plugged in, I noticed a glow in the back behind the panel. Unplugged it...did I ruin my frezzer? it a model # TFX22KRDWW
    President:
  • 1,136 Answers
HI, The glow was probably the defrost heater. If you didn't have any smoke or flames, you probably just happen to see the defrost heater come on. It would of been behind he rear panel down near the air vent.
I hope this helps you.
Vic
Posted on Jun 22, 2009
Water dripping into fridge from freezer. noticed red hot element in back of freezer behind vent inside freezer
Heater glow behind frz back wall is normal during auto defrost cycle. This happens about 2 or 3 times a day for approximately 30 to 45 minutes. The water migrating into the fresh food section could be from a blocked drain tube which should be be in the area directly under the red glow you noticed. Should be a hole going through the floor into the drain pan under the refrigerator. Force hot water down hole until it flows freely.
Apr 07, 2015 | Refrigerators
Ge side by side I have to keep defrosting the freezer every 2 months or so the temperature starts going up the fridge runs more often when we remove the back panel within the freezer it is built up with...
Do this when the refrig starts to warm up . Don't defrost before this test .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge broken, freezer is temp. that fridge should
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 26, 2010 | GE GSS20IEP Side by Side Refrigerator
Whirlpool etowsrxmq03-- back wall of freezer is
Good day,
Yes that is normal. It is going thru one of it's automatic defrost cycles to melt off excess frost building on the cooling coil mounted behind the rear panel in the freezer section.
The red glow is the heater doing it's job. It does this for a short period of time, and causes the rear panel to become somewhat warm, but only for a short period.
It only occurs about once a day randomly, and lasts only 21 minutes, so the odds of seeing it are rare.
Jun 05, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
In the freezer, bottom of the rear panel there are two vents. Behind those vents I noticed a red "glowing". The fridge is brand new. Is this normal?? Please help. Thank you in advance.
yes every new fridege comes with a radio active grimlin this is perfectly normal just remember to feed it or it will eat your pets and **** on your floor thank you that is all
Apr 03, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
My ge side by side model gss25jfmc ww will start to freeze food in the cool side then it stops cooling in the freezer side. Ice will form on the back wall of the freezer. I haved thawed it out &...
I can tell you how to find the problem , but , it is a little work .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Top of freezer not freezing and refrigerator not
Dirty coils not likely the problem .
Open the freezer door .( Behind the back panel ( inside the freezer ) is the evaporator fan motor . ) Push in on the freezer door switch , and listen for the fan to come on . Sometimes , the fan will stay on , even if the door is open . Do you hear the fan ? If not , then the main control board , behind the refrig , behind an 8 " X 10 " panel , is probably bad . If you do hear the fan , then you are having a defrost problem . Pull the refrig out and remove the 8 " x 10 " panel .
Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off , due to set temperature reached .
Dec 10, 2009 | GE HSS22GFT Side by Side Refrigerator
Running but not cooling
Pull the refrig out , unplug , and on the back , remove the 8 " X 10 " panel . Behind this panel , is the main control board . On this board , you will see a blue plug ,with 3 larger wires going to it , which you need to unplug .
You will need a short piece of insulated wire , with both ends stripped about 1/4 inch .
Looking at the plug , you will see : wire1 wire2 space wire3 . With the piece of wire , insert 1 end into wire2 , and the other end into wire3 .
Plug the refrig back in . Looking in the freezer section , behind the crisper , after about 1 min , you should see a " red " glow .
If no red glow , this means your defrost heater AND bimetal need to be replaced . Unplug the refrig , remove jumper wire , and plug the blue receptical , back onto the board . Reinstall the panel .
To replace these , remove the food in the freezer , and remove the inside freezer panel ( 4 screws hold this panel on ) , and the heater is below the coils ( 2 screws ) , and the bimetal is clipped on the top of the coils , a 1 " cylinder , with a pink and blue wire going to it .
Part number for the heater WR
Oct 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our freezer on our ge profile side by side is not staying cold
Pull the refrig out from the wall . Behind it you will see an 8 " X 10 " panel , held on by several screws . Unplug the refrig and remove the panel . On the control board , you will see a blue plug with 3 larger wires going to it . Unplug this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire with both ends stripped about 1/4 " . Insert one end into wire2 and the other into wire3 . Plug the refrig back in . Open the freezer door and , at the bottom of the rear panel , do you see a red glow ? If no glow after about 1 min , then the defrost heater is probably bad . To replace this , you would have to remove the rear freezer panel , and under the coils , will be a glass tube . This is the heater . If you do see the red glow , then either the board or the #4 and #5 thermistor are bad . Start with the thermistors . Small 1" white cylinder , with 2 white wires going to them . One is clipped on top of the freezer coils , and the other is at the bottom of the freezer panel , inserted into a holder . These thermistors , tell the board the temp of coils , and freezer .
Sep 19, 2009 | GE Refrigerators
Our Freezer section bust into flames
Could you take pictures and allow me to post your story. This is interesting and I believe it will be information for all to know and be concerned. Thanks, Sea Breeze appliancepartsse@gmail.com
seabreezehvac@yahoo.com
Mar 31, 2009 | Smeg FA561X Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
207 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
