Question about Fuji Finepix S3200 S-3200 24x Zoom 16123737 074101007954 Hd Digital Camera
How can I get a evf/lcd button that fell out?
How can I fix the button that turns on the EVF and turns off the screen? It isn't working.
sir,
I don't understand your question!! how can we use EVF for this model in which it is not fixed from the company, the tilting type LCD is very clear and user friendly in this model.
some old models comes with EVF there may be a small switch beside the EVF. and in some models comes the switching options in the setting menu. if your model is like that you try it in the S-menu.
Jan 10, 2016 | Sony Cyber-shot DSC-HX1 Digital Camera
Help! Won't turn on
Fuji suggests; "If the digital camera will not turn on, run through the "Checklist" given below. If this does not solve the problem, take the camera, the batteries, and the AC Power Adapter to an authorized FUJIFILM service center for testing and repairs. [Checklist] 1. The direction of your battery might be wrong. Confirm it and put it again. 2. Load new or fully charged batteries. 3. The battery terminals may be dirty in a way that cannot be seen (fingerprints, etc.). Wipe the terminals clean with a soft cloth. 4. Press the Power button again firmly." Cleaning the battery contacts sounds worth a try. Fuji also say; "Please use only alkaline batteries or Ni-MH rechargeable batteries with Fujifilm digital cameras Please note that instruction manuals provided with Fujifilm digital cameras recommend that only alkaline batteries or Ni-MH rechargeable batteries are used with those digital cameras which require AA or AAA type batteries. If other types of batteries are used together with an AC adaptor, this may result in the rare occurrence of the battery overheating. Please do not use batteries other than those recommended in our instruction manuals." Check that the type of battery is correct Did you buy the camera new? is it still under warranty? Here is the link to the support page for the s7000 including manuals, repair centre details etc; http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportBrowse.jsp?prodcat=616757&sscucatid=664272&sscucatid=664271 or direct to the manual; http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf Apart from contacting Fuji for service, the only suggestion I could find in the manual was that the battery cover may not be closing fully. Worth checking. Hope this helps :)
Jul 01, 2007 | Fuji FinePix S7000 Digital Camera
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
Can't see anything through the eypiece
To switch between the LCD screen and the viewfinder use the button EVF/LCD. to switch back, use the same button.
Nov 04, 2013 | Pentax X70 Digital Camera
Have a fuji finepix S5600, but my lcd remains black even the camera is on! i can see the pictures i already made at the lCD. But LCD is not working if i want to make new pictures??
Hello, I think I know what the problem is..we'll see. On the back of the s5600 there is a button marked EVF and LCD(EVF on top LCD underneath) try clicking this button to see if your LCD screen becomes available, only one of these can be used at a time and the default for playback is the LCD screen. However if you have set it to EVF it will revert back to this format when you leave playback and try take new footage. I hope this helps and it is nothing more complicated. I have some problems myself and know how it feels. Alan
Aug 29, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
Wiew finder not warkig.
on most cameras you cannot set the lcd and the viewfinder at the same time, there should be a button that says 'LCD/EVF' or another button, it will be in an online manual
http://finnsharp.daportfolio.com/
Apr 16, 2010 | Canon Rebel XS / Eos 1000D Digital Camera...
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
Jan 04, 2010 | Fuji FinePix S5000 Digital Camera
Cant view photos on the big screen of my camera
I think you must have pressed the EVF/LCD button which changes the review area to inside the tiny view finder.. the EVF/LCD button is found on the back of the camera at the top left hand corner.. it is a little silver button. Hope that helps.. :)
Jun 01, 2009 | Kodak EasyShare DX6490 Digital Camera
My Fuji Finepix S2000hd has lost all LCD fuctionality
My S1000fd has a EVF/LCD button. It is used to switch from Screen to veiwfinder. Is it possible you pressed it by mistake when the camera was turned on ?
Feb 19, 2009 | Fuji FinePix S2000hd Digital Camera
The colour on the EVF and LCD is pretty pink and nearly red
Yes it is. I believe Panasonic knows that the built in flash casts a very blue tint so they set the flash WB to very red to compensate. Therefore before the flash is triggered as when you watch the LCD. Some threads here even suggested adjust the WB further 2 knots to the red manually (press " up" a few times on the 4-way button to have better skin tone. Try it. The setting stays even when you turn off the camera.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Fuji Finepix S3200 S-3200 24x Zoom 16123737 074101007954 Hd Digital Camera Logo
15 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
