Question about Hayward Pool & Spa
Control panel locked out pump and now it doesn't operate
    Top Expert:
  • Hayward Master
  • 7,897 Answers
Turn off reset and try again
Posted on Dec 09, 2017
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
Control lock button is on and will not clear to wash clothes
Hi, Whirlpool makes their control lock very confusing. Often times, people will look on the control panel and the control lock light will go on and they can not figure out how to unlock the control panel. They will try pressing and holding the cancel button and unplugging the washer or dryer to reset it. None of these options work. All you need to do is press and hold the end of cycle button for 3 seconds and the control panel will unlock. If that doesn't unlock your controls, then unfortunately your interface control board is just shorted and will need to be ordered and replaced to fix the issue.
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does the code p1494 for a 2000 jeep grand cherokee mean?
The code refers to the leak detection pump that is part of the gasoline vapor control system which is for pollution minimization. It says either that the pump switch or mechanical operation is faulty. According to a Chrysler manual I have, you would find the pump, probably on the underside of the vehicle by tracing the hoses related to the vapor recovery tank that may be in the right front corner of the engine compartment (I don't know Jeep designs) and then check to see if the pump starts when you turn the ignition to the run position when the vehicle is cold. Then remove the vacuum hose side of the pump and see if it draws a vacuum. If it does, then the vacuum-detecting switch that detects that the pump operation is OK may be faulty. If the pump doesn't start or doesn't draw a vacuum then the power to the pump, the pump itself, or the vacuum line may be leaky. Finally, the powertrain controller could be at fault.
In any case, that is where the issue is, and it should not be a major issue if it is handled by a knowledgeable mechanic. But you could check it over yourself if you are so inclined.
Jun 03, 2011 | 2000 Jeep Grand Cherokee
I locked my front panel by accident and have no remote for my rca 20F514TD..how do I unlock?
Hello
To open front panel control function you must have its Origitnal Remote control. If you have lost it, try to borrow it from your friends or relatives; who owns the same model of TV as you have; just to unlock the front panel lock.
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
Jun 02, 2011 | RCA Televison & Video
Controlboard locked,how to unlock
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can normally be reset and usually is not an indication of a malfunction.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Jun 08, 2010 | Kenmore 42822 Front Load Washer
My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control locked signal is on. and it won't let us do anything.
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have LOC on the control panel and I am not able
To Unlock Main Control Panel: Press DISPLAY, MODE, and DOWN buttons within five seconds. The “lock” symbol will disappear. All buttons are now active.
Sep 17, 2009 | Pool & Spa
What does LE mean on the control panel
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
May 25, 2009 | Dishwashers
Pool & Spa Logo
21 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
