Question about Garden
Murray 8hp riding mower, engine runs, engage blades, engine dies.
2 Suggested Answers
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
I have a 17.5 Murray riding lawn mower engine runs well when I engage the blades it spits and sputters and starts backfiring what could be the problem
Sounds like bad fuel....runs fine when not under stress but poops out under pressure. Drain fuel and refill with new mix if it's a 50/50 gas-oil blend.
Apr 26, 2016 | Murray Garden
Model 40808X14A. When blades are engaged, why does mower die?
Most likely something is jamming a blade.
Another possibility is the reversing safety switch is stuck which cuts the engine spark.
Apr 15, 2016 | Murray Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
I have an old Murray 38608b. It runs great until I engage the blades. Then it sputters and the engine dies. I want to fix this myself if I can. Help! Thanks!
Try turning blades by hand. Should turn. May need clean bottom. May be to much buildup. ALSO CHECK YOUR SPINDLES BEARING OUT.
Jun 20, 2014 | Garden
I have a problem with the safety switches on my riding lawn mower
e841a1bd-a315-49bb-ae7c-9ba2aedccbb6.gifCheck this diagram. It is most likely the deck switch. as this is a safety switch i would recommend replacing it instead of bypassing it.
Jan 13, 2014 | Murray Garden
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
Jul 31, 2013 | Garden
Safety switch located
Micro switches will just stop the engine if the blades are engaged and the operator leaves the seat, or will stop the engine cranking if the blades are engaged, it will not stop the blades from engaging.
Sep 06, 2012 | Murray Garden
Motor runs fine but can't go foward or backwards on Murray 8hp rear engine riding lawnmower
check the drive belt it might have broke or fell off a pulley
Apr 27, 2012 | Garden
Hi, I have an older Murray ride on mower, small
Sounds like you have some sort of seize up problem in your deck assembly. Have someone help you with this check, start your engine, engage the blade or blades, and have someone watch the shoot from a distance to see if blade or blades turn. if not then your problem is in the area of top pulley and blade or blades. You may need to replace or loosen the pulley to blade shaft. Sometimes this part is repairable where you can replace bearings or bushings and sometimes the whole unit needs to be replaced. Look to see if there are grease fittings on this unit. Try oil anywhere it will flow down in between areas that may be seized and work on loosening up the pulley blade assembly.
If this doesn't help, go to some of your local mower repair shops, they may be able to sell you a used part. Remember to bring mower information with you so they can help you with the correct part.
I hope this has been helpful to you. GOOD LUCK.
Jul 19, 2011 | Briggs & Stratton Briggs Stratton...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
