Question about Garden
I have Troy built pressure washer model 020209,low pressure ,an oil comes out carb,is there too much oil in it?
2 Suggested Answers
  • 76 Answers
SOURCE: Troy Bilt pressure washer model 020209 has very
you are going to need a pump seal kit or they may call it a rebuild kit but this sort of thing happens often and you should not have any trouble getting the parts you need with the kit should come a exploded view diagram but request one just to make sure be careful when putting it back together if gyou damage any of the brass or neoprene parts you will be putting it together for nothing lay out your parts on a clean towel keep all dirt and grime away and clean your pump housing really good before you put the new parts in and i mean clean enough to eat off of if you do all of these things your rebuild will probably last longer the the original good luck and get back with me if you need help with the rebuild
Posted on Jun 29, 2009
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
Jul 27, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy Built 2500 pressure washer, gass filled cylinder, oil is comtaminated, can it be fixed
Anything can be fixed but you may need more specific help.Gas filled cylinder and contaminated oil may be linked to the carb flooding the bore and gradually getting into the oil. Fixing one fault may fix all. See why the gas fills the cylinder, then fix that. Change the oil and go from there, don't change anything unless you are sure. Keep in mind the economics of the repair costs. Checking everything is functioning as it should usually reveals the problem.
May 19, 2014 | Garden
Whre do you put in the pump oil on a troy built pressure washer
THERE MIGHT BRASS FITTING ON THE SIDE OF THE PUMP THIS IS WHERE THE OIL SHOULD GO BUT FIRST SEE IF ANY OIL WILL COME OUT. FILL THE PUMP UNTIL THE OIL STARTS COMING OUT I HOPE THAT THIS WILL HELP
May 05, 2014 | Garden
NO water coming out troy built 2200 pressure washer
did you install the key on the flywheel
May 01, 2012 | Garden
Troy Bilt pressure washer model 020209 has very low spraying pressure. How do I repair the pump?
Jun 29, 2009 | Garden
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Jun 09, 2009 | Briggs & Stratton Gas Pressure Washer...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
