Question about Sharp 56DR650 56" Rear Projection HDTV
MY REAR PROJECTION BULB IS BROKEN AND THE SCREEN IS COMPLETLY BLACK
Got a Mitsubishi vs-8070, everything works fine then the screen turns off after about 15 minutes sound still works fine. Help.
Does this unit have a projection bulb in the back end of the set? Just based on my experience with a friend's 65 inch rear projection TV, there might be an indicator light on the front panel that may blink if the rear projection bulb is failing. If there is a failing bulb it could account for the screen going black with everything else just fine, after the bulb gets heated up in 15 minutes.
Oct 15, 2014 | Televison & Video
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
I need to know how to chage the screen lens ?
I was watching my 56 inch RCA tv when it made a sound like a broken bulb and went out. Now when I turn on the tv it only makes a little noise and the screen is black. I have had this tv for approximately ten years, bought it brand new.
Mar 11, 2010 | Toshiba 51H83 51" Rear Projection...
Mitsubishi 65 inch rear projection 7 years old, the screen strted to look like a 3D picture without the glases on, then went off completly, no green light and will not power up
replace toe to big ics in the center of main board the # on the ic stk560
because you kept on running it then check for fusable resisters thay look like little black resisters with no colors on them
Sep 27, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Screen replacement??
screens are quite expensive relative to the tv.. is the screen busted completly or just the top plasitic/ averge part cost are around 250 to 350 for the set of screens... places like union electronics is the place where my shop gets rca parts. not difficult to replace. you need the complete model number like hd52w59yx1. to get the correct replacement
Oct 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The screen is completly in Black
When you say the light is in standby what do you mean? Is it blinking? if so how many times? and what color? Is it solid? if so what color. If you provide this info i will be able to assist you better.
Tim
Experttv@comcast.net
Sep 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Picture but no sound.
I'm not sure of your particular model, but in general: in the rear of the unit is usually an access panel which you can remove. The bulb should be centrally located and is usually found within some kind of enclosure as it is EXTREAMLY bright and will blind you if you look at it directly. It is also located near a fan which is to keep it cool under operation. The bulb is approx the size of a small fist.
I know this is really obscure, but i hope it helps.
May 10, 2008 | Philips 60PW9363 60" Rear Projection...
Sharp 56DR650 56" Rear Projection HDTV Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
