Question about Ducane 30400040 Stainless Steel Grill
How to replace battery on ducane stainless grill
SOURCE: burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Posted on Oct 26, 2008
  • 3 Answers
SOURCE: I lost my Manual to my grill
www.appliancefactoryparts.com will help you good luck
Posted on Mar 28, 2009
landsend
  • 1066 Answers
SOURCE: How do I install the replacement igniter in my
you remove the nut in the back of the old igniter and the single wire that plugs into the end.  Then you pull the unit out.
Next, you insert the new igniter and replace the nut and tighten then reinstall the one wire into the end.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on May 02, 2009
  • 9 Answers
SOURCE: I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Posted on Jun 26, 2009
fathitkf
  • 1871 Answers
SOURCE: how do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Posted on Feb 21, 2010
How to replace burners
Replacing the burners on any Ducane Gas Grill is not an easy task. As the control panel has to be dismantled to accomplish it. With that in mind, I have included a link to the Owner's Manual. The section Annual Maintenance starting on page 21, will be a big help to yo in removing the old burners and installing the new ones.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
Hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Aug 02, 2011 | Ducane 30400040 Stainless Steel Grill
I want to clean the grill but cannot find the owner's manual to determine how to take it apart and clean it properly. How can I get a manual?
Here's a link to the Owners Manual for a Ducane Stainless Steel Grill, that may be a little newer than yours. Never the less, the maintenance and cleaning are the same.
Happy Grilling!!
Jul 15, 2011 | Ducane 30400040 Stainless Steel Grill
How to replace bbq tube burner for ducane grill
You can dowload a manual for your gill from the ducane web stire. Pictures and instructions are in the Annual maintenance cleaning section. You will need Adobe Reader to view thw dowload. Web site: http://www.ducane.com/manuals/
They have Meridian and Stainless models in 3 & 5 burner for LP & NG.
Apr 16, 2010 | Ducane 30400042 (LP)
How do I remove the old burners to replace with new?
Should be as easy as removing the screws at the ends of the tubes and sliding the tubes away from you and putting the new ones in like you took out the old ones.
Apr 10, 2010 | Ducane 30400040 Stainless Steel Grill
Ducane model number 30400040 just received set of (3) stainless tubes to replace the old ones whats the easy way to install
goto ducane web site http://www.ducane.com/manuals/
and download manual. They have Meridian and Stainless models in 3 & 5 burner for LP & NG. Follow 1 year cleaning instructions. Pictures and instructions.
Apr 05, 2010 | Ducane 30400040 Stainless Steel Grill
Ducane 30400040 Stainless Gas Leak
Call Atlanta Grill Services they are on the internet. they can get the part for you
Aug 14, 2009 | Grilling
Ducane stainless steel NG BBQ with uneven heat front to back
all grills are hotter in the back than the front even if you bought a grill that was 6000.00 it will do the same thing
Jul 26, 2009 | Ducane Affinity 3100
Ducane 30400040 Stainless Steel Grill Logo
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
