Question about Seiko Watches Seiko Quartz 100m Womens Dress Watch SXDE67P1 SXDE67P SXDE67
How is this watch solar
Does this watch work on solar
Do Coifman watches work by battery or are the solar powered
Do you see a itibiti tiny solar panel in the face of the watch? If not like all watches it uses a tiny button battery
Jun 07, 2016 | Watches
The watch stopped working. It is solar powered, but does not work.
Take the watch to the jewelers, if the rechargeable battery has failed or solar power issue, it needs to be checked out by a professional.
Jan 05, 2011 | Watches
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
May 14, 2009 | Casio Watches
I have a casio triple sensor solar watch (prg-50). It constantly reads 'Open'. Does this mean the battery is dieing??
Casio solar watch has no battery it is powered by solar,but there is a storage capacitor like a battery.It will last for 5years that capacitor.Try to hold all the buttons and press hold simultaneuosly for 7 seconds this for reset the watch..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE.
Jul 29, 2008 | Casio Watches
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Manual
My victorinox 24731 has gone silent. the alarm sounds if i lift the back flap and push a little black disc in the rhs bottom corner. but it does not work when i set it . it has been working perfectly for the past six months
Sep 18, 2007 | Casio G7301V8V Tough Solar G-Shock Gray...
Seiko Watches Seiko Quartz 100m Womens Dress Watch SXDE67P1 SXDE67P SXDE67 Logo
11 people viewed this question
Top Seiko Watches Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Seiko Watches Watch Expert? Answer questions, earn points and help others
