Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Light is very dim and it is not on dim - that makes it even dimmer. PSTX Series
2 Suggested Answers
SOURCE: I have a PSTX Series
Had the same issue. You have to let it run a cleaning cycle before before the light goes off. Turn machine off, empty pot, add 4 cup cleaning solution and hit the clean button (not the brew button). Let it go through this slow cycle like it says in the manual and it should reset itself.
Posted on Dec 07, 2011
Dash lights in my 2003 buick century will not dim and will only come on after I turn dome light on then off
a little complicated but here's the deal. most dash light dimmers are really a rheostat and by what you are describing, the coil portion of the rheostat is 'fried' but this will still allow the non-dimming portion of the coil to operate non-dimmed. the dome light part of this is actually another separate switch that is engaged once the max dash light adjustment is reached, it has little to do with the dimmer what-so-ever. This is at least a $200 (or more) repair from a good shop, could be even pricier at a dealership, not counting the dimmer itself.
Sep 13, 2014 | 2003 Buick Century
Humming and failure to dim
Bad dimmer. Probably not using a high enough watt rated switch. Add up the total of all bulbs to be dimmed and get appropriately rated dimmer. 8x60 watt bulbs=480 watts. Make sure dimmer is rated high enough.
Feb 09, 2014 | Leviton Decora Light Dimmer Switch
Using 3 way dimmer, lights don't appear to go to full light
Hi Gene,
When two 3-way switches are used to control a light - and you wish to install a dimmer, you replace only ONE of the switches. If you replace both switches with dimmers, and one dimmer is set to 50%, the light will only be able to get to 50% bright; regardless even if the other switch is set to 100%. The light can only get as bright as the current lowest dimmer position of either switch.
Most modern dimmers are solid state, and should be able to get full power to the lamps. Older dimmers aren't very efficient and work a little differently - but should still do a good job as far as brightness of the lamp. You can run into trouble trying to dim CFL (compact fluorescent lamps) if they are not labeled specifically for use with a dimmer. Even those that are labeled for use with a dimmer have a noticeably short range of dimming when compared to standard tungsten lamps, and tend to have an audible buzzing sound.
If this doesn't answer your question, please provide the wattage, type and number of lamps in the fixture. Your dimmer is rated for up to 600 watts, but may be less if it is in a switchbox with other dimmers or you have broken off portions of the heat shield as directed by the instructions.
Mar 17, 2012 | Lutron AY603P Ariadni 600W 3way Dimmer...
I want to set up two household light (AC) both of which are to be controlled from one switch with a dimmer. can I connect the lights in in series or do I have to connect them in parallel with two separate...
The dimmer controls the intensity of the electric current flowing in the circuit, hence controlling the light intensity emitted from the bulbs. I believe a series connection with one switch will suffice.
Jul 23, 2011 | Office Equipment & Supplies
I have a PSTX Series of Mr. Coffee and the clean light is on. I have cleaned the coffee machine and light still won't go out. I even unplugged it for awhile and it still comes on after I make a pot of...
Oct 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Dashlights are dim
I know this sounds trivial, but make sure you or someone didn't inadvertently bump the dimmer switch. If you slide the dimmer all the way up and even past the slight little catch so that they are continously on high and still seem dim, there could possibly be an issue with the dimmer switch itself.
Apr 02, 2009 | 1999 Infiniti.5 QX4
Dimmer switch is not dimming
florecent bulbs wont dim unless they are dimmable.
Dec 24, 2008 | Lutron ELECTRONICS CO. Q-603PH-WH "QUOTO"...
How many dimmers types?
Certain dimmers can control standard incandescent lamps that use 120 volts while other dimmers can control low voltage xenon or halogen light sources that use 12 or 24 volts.
Aug 27, 2008 | Lutron Electronic Low-Voltage...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
35 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
