Question about Electronic Arts Need for Speed: Rivals - Xbox One
How to use my ferrari spider wheel? - Electronic Arts Need for Speed: Rivals - Xbox One
Amber slow down onmy Ferrari f430
www.reliable-store.com you can download it from here
Aug 21, 2015 | 2007 Ferrari F430 Spider
Sticky auto parts in cabin of 360 modena 2002 Spider most controls are sticky
This is a standard problem in Ferrari, you can only treat it and no cleaning can be done as the plastic will drop off. totally. Home
Jun 07, 2012 | Interior for Ferrari 355
Ferrari 360 Fi spider instrument back lighting doesn't work, fuses are checked ok , what to do?
Time to open up the cluster and check for bulbs being out, or a shorted wire. Do the dials and gauges still work, and is there a dimmer on your model. I remember the older Ferrari's' having a dial type dimmer, you may have moved it to the lowest setting that would make them appear off.
Jul 12, 2011 | 2004 Ferrari 360 Modena
How to change a timing belt on 2003 ferrari 360 spider
The 360 has an access panel behind the seats. To get to the panel the interior trim behind the seats has to be entirely removed. Assuming that you have changed belts before, as an interference engine with tight tolerances, you can not be off one notch without destroying the engine.
the tensioner pulleys should be replaced with the belts. you can spin the bearings to check them but after all the work getting there I would replace them. tension is set through eccentrics.
Dec 01, 2010 | 2003 Ferrari 348 Spider
Where is the battery shut off switch for the 2007 ferrari F430 coupe?
The battery shut off is in the back of the trunk passenger side, Black knob
Sep 13, 2010 | 2007 Ferrari F430 Spider
2003 Ferrari 360 spider convertible issue
The most common reason for this is low hydraulic fluid. The noise is probably the pump running while empty. When fluid id present it dampens that noise. Behind the rear seat is the combination motor/pump/reservoir. With the top in the DOWN position, fill the reservoir with ATF and cycle the system a few times as far as it will go. Repeat until the reservoir will take no more fluid. If that works, it is only a patch fix. You must now inspect the lines, motor and cylinders for leaks. The fluid does not evaporate. If it is low, you have a leak. Karl at topgunwon.com
Jan 01, 2010 | 2003 Ferrari 360
Flat Battery in F430
it should be under the aluminum plate, where the passenger rest his feet on! this is where i have it on my 2008 F430
Jan 25, 2009 | 2007 Ferrari F430 Spider
Ferrari 360 dead battery
Correct, the battery is in the passenger footwell under the aluminum plate. It is perfectly fine to charge the battery here, but it is not recommended to jump start. Also, it is possible to get in the trunk without having power. There is an emergency release pull tab under the drivers side dash. Quite easy to use, actually I normally use this in lieu of the normal electric release.
Dec 14, 2008 | 2004 Ferrari 360 Modena
Replace the timing belt
It is recommended to replace both the timing belt and the tensioner bearings every 30,000 miles for the models you listed. Other models like the 360 Modena are best replaced every 3 years. The cost (parts and labor) to replace the timing belt on both the Ferrari 308 and 328 will run about $3,000. The Ferrari 348 will cost a bit more at $4,000. No Ferrari is inexpensive to maintain. However, the 308 and 328 will be the least expensive for basic maintenance. Furthermore, if you plan to drive under 2,500 miles per year (or 5,000 miles - 2nd tier), you can insure the car as a collector's vehicle and pay a much, much lower insurance premium.
May 15, 2008 | 2003 Ferrari 348 Spider
Electronic Arts Need for Speed: Rivals - Xbox One Logo
468 people viewed this question
Top Electronic Arts Video Game Consoles & Games Experts
 Shayaan Tanwir
Shayaan Tanwir
 TE5LA
TE5LA
Josh Whitehead
Josh Whitehead
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
