Question about Garmin nuvi 200W GPS Receiver
My GPS continues to search for satellite and can't seem to find where we are.
    Brigadier General:
  • 4,090 Answers
How to have a lost weekend Use GPS!
a few things to check
Good view of the sky
Well charged battery preferably on AC charger before using
Low battery power will affect connection.
Burned out SIIRF chip ( big money to have repaired!)
usually caused by plugging GPS into car DC power and then starting engine. Not recommended!
Posted on Jun 23, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: Searching for satellite but never finds - what is wrong?
I had one like that last year, I found if I lied to it when it asked what state I was in, then it would find the satellites and work fine ... until the next time you turned it on. That one was fixed by installing new v7.2 firmware using Garmin WebUpdater through the USB port.
I've got one right now that won't find the satellites and the firmware trick didn't work. That's all I've got so far. Tom.
Posted on Jan 24, 2009
I have a ifinder hunt GPS, it will not locate any satellites, it then prompts me to stop searching or continue to search for satellites. I have been trying this device over the last 10 months, mostly on...
With a normal GPS device, when you first switch it on, it needs some time to locate enough satelites. Most of the time it needs at least 5 satelites. Some time should be like minutes and not hours. After the GPS device fond enough satelites, it knows where it is and can when it is switched on again work faster. When you try to let the GPS search for satelites indoors, or without a free view to the sky, it is possible the receiver never can find satelites at all.
I don't know if any test of the Lowrance iFINDER Hunt GPS was placed on the net, but that is where you can check how long it should take for the GPS to find enough satelites.
Oct 30, 2013 | Lowrance iFINDER Hunt GPS Receiver
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
Why tomtom always say to me that my device is not connect
When the GPS device is not able to receive (more than 3 or 4) satellite signals, it will continue to search. This may take a while ... or if you're indoors or under cover of some (solid) obstructions, it may not happen. So, make sure you have clear views of the skies when you are trying to get satellite signals.
Consider regularly updating the GPSQuickFix file (by connecting your GPS using TomTom HOME) to download the positions of the satellites (over the next 7 days). It may help.
May 01, 2013 | Tomtom GO 720T TMC
How to force pioneer u310bt gps to search for satellites
The GPS should automatically search for satellites unless it is in Demo or Simulation mode.
Be sure to turn of the Demo mode.
Use the Navigation screen and touch the Demo button to turn on or off the mode.
Jan 25, 2012 | Pioneer Avic-u310bt GPS Receiver
I am having trouble getting location. Even when I get good satelite coverage (many showing on the screen) No location shows. It also seems to be slow in acquiring upon power up. How do a restore the units...
Hi!
i checked out the Garmin owner's manual for your GPS:
http://www8.garmin.com/manuals/eTrexVista_OwnersManual.pdf
On page 6 it explains that from the satellite page there are four options from which you can choose;
1) Use with GPS off
2) New location
3) Restart search
4) Continue acquiring
If the date displayed on your unit is NOT today's date, select "Restart Search"
Since the GPS does NOT lose memory when the batteries are removed, the problem is unlikely to be that the GPS doesn't know where it was used last.
If the displayed time for your area is not correct, use the main menu to access the setup pages and follow the instructions for setting the time found on page 49. This SHOULD get you on your way.
May 02, 2010 | Garmin eTrex Vista GPS Receiver
Will not get a satellite fix...continuous searching
weak battery will do this, average life span of GPS batteries is 2 years.
Dec 07, 2009 | Magellan RoadMate 700 GPS Receiver
Does not acquire satellites. Tried waiting.
try updating with the latest GPSfix updates from the tomtom home software
Aug 04, 2009 | Tomtom ONE GPS Receiver
Won't locate satellites each time you turn it on.
The GPS does not have a line of sight to the satellites. Relative satellite position may vary somewhat through the year as the Earth wobbles on it axis. Reposition the GPS in your vehicle.
Sep 16, 2017 | Garmin Forerunner 205 Gps Running Watch
Garmin GPS acquiring satellite Issue
I would return it to Garmin for service.
Mar 23, 2017 | Garmin nuvi 200W GPS Receiver
Locating satellites
This takes about 15 to 30+ min. Make sure you are in an open area and NO XM or serious receivers turned on!
Nov 27, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
193 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
