Question about BaBylissPRO MiraCurl
How do I fix it?
It starts, spins, and stops at all the wrong times.
Motor spins over will not start and backfire thur the crab I got the valves gap is good and their are caps that go on the end of the valve spin are their suppose to be to of them
trying to make sense of your statement
The motor is backfiring on starting-- that is valves open, wrong valve timing or wrong ignition timing or firing order
As to caps on the ends of the valve stems --their purpose is to release the spring retainer in the groove of the valve stem and so allow the valves to rotate to stop anything holding the valve of the seat
this stops exhaust valves burning and allows inlet valves to seat properly
May 27, 2015 | Measuring Tools & Sensors
Electrolux dryer getting 'stuck' at times
the belt is frayed and catching at times. mine was split in half. right down the middle.gets caught on tention pulley as it goes around,,,sometimes
May 10, 2014 | Dryers
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
How to reset my washer, I am having problems with the washer, it does not want to spin on the final cycle; however it does wash. what could possibly be wrong and how can I fix this?
Please remove power for a while and allow unit to drain out the residual voltage so as to reset. Now press down the start /stop buttons prior to plugging the unit. Select a different program and see the timing of the water low into the inlet and in the drain cycle. If you notice that the flow is low then clean or replace the inlet valve, check the water level controller to stop inlet flow and start wash and finally the drain and refill for rinse spin. if not there is an error in the program for the refill and must be checked on the drain and level controller.
Sep 27, 2011 | Frigidaire GLTF2940ES Front Load Washer
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The brushes have stopped spinning. This is a
the brush spins on a bearing, you might want to get to the bearing and make to it has not cracked or broken.
Nov 30, 2009 | Kenmore 33923 Bagged Upright Vacuum
I have a quiet series 100 and clothes are soaked after final spin cycle. drum spins but agitator is stopping and starting. Only one time in about 10 will it ever get up to full spin speed. How do I fix...
This could have something to do with water not draining properly and slowing the drum down. Check the drain hose position and see if it's emptying the water out properly. Your machine may have an internal filter that could be cleaned. Then there's all the things that could be wrong with the gearbox, motor, electronics, etc. If it's not a draining issue it'd probably be better to let a professional work on it for you.
Oct 24, 2009 | Maytag Washing Machines
BaBylissPRO MiraCurl Logo
142 people viewed this question
Top BaByliss Health & Beauty Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
