Question about Addie Water Systems Metered Water Softener
My pressure is bad - Addie Water Systems Metered Water Softener
    Sergeant:
  • 239 Answers
Most likely a failing water softner. Have it services asap. Or replace the resin yourself but do it quickly. Bypass the softner in the mean time. There is a valve assembly on the head of the softner. Set it to bypass.
Posted on Mar 31, 2015
  • Nick Tumolo May 29, 2015
    Yes it is repairable. It needs to be serviced
I have a 01 chevy blazer with a 4.3 vortec engine I want to no if a faulty fuel injector spider would cause low fuel pressure
low fuel pressure is from
bad pump,
blocked filter,
faulty pressure regulator
evap system not venting tank properly
leaking injector seals
Feb 13, 2017 | Cars & Trucks
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Why does my rear air suspension system come on nothing leaking but my 2002 Oldsmobile bravada will not go up
Bad pump or a leak. Pull the lines fro the rear air shocks, Fell for pressure build up in the line. Find the pump, and check pressure there also. No pressure at the pump, it's bad. Pressure at the pump, but not at the shocks, bad line. Pressure at the shock line, bad shocks.
Jul 10, 2015 | Oldsmobile Cars & Trucks
Computer show the engine oil pressure not enough need to stop engine how to improve
Generally low oil pressure is due to a failing oil pump. If you have a mechanical gauge you can pull the electric oil pressure sensor and use that gauge there to verify if the pump is bad. If pressure is low on the mechanical pump then the pump is bad. If the mechanical pump reads good pressure then its the pressure sensor that is bad.
Apr 02, 2015 | Cars & Trucks
Has no oil pressure i drove it over ten mile still runs good but no oil pressure
Just because it runs good is no reason to drive it into the ground. No oil pressure can ruin an engine fast. Hopefuly the reason no oil pressure is the sensor is bad, it's connection is corroded and thus bad. If mine I would take it to a shop and have them actually measure the oil pressure with a mechanical gauge. If no oil pressure that way, you know you have a serious problem. If the mechanical measurement is good, then you know that The sensor is bad, it's connection is bad, or the oil pressure light or ? gauge
is bed on the dash panel. Good luck.
Mar 15, 2015 | 2007 Chevrolet Tahoe
What will be the problem if the common rail is having low pressure?
Hi
common rail pressure low problem could be:
1 bad hi pressure pump
2 bad rail pressure monitor sensor
3 bad pressure regulator sensor
4 bad injector/s back leak
Aug 15, 2014 | Cars & Trucks
Oil pressure
Oil pressure problems:
Bad oil pressure sensor.Bad wiring May touch grounded parts leading to red low pressure signals.Bad (thin) oil.Cloged filter.Bad/worn oil pump.Worn cranckshaft bushing.Rare:loosed/worn valve shaft.
Cheers, hope u deal it well,share.
Oct 27, 2013 | 2006 Volkswagen Passat
P0845 Transmission Fluid Pressure Sensor/ Switch B Circuit
Hi Adam, Thanks for your response. To check the bad sensor or a bad transmission pump how much it may cost me to fix the issue?
Jun 20, 2012 | 2005 Chrysler 300
No pressure
The pump has burnt up...thbey are cheap units and go bad.
its not a ? of will the pump go bad, just when...they all go bad
Jul 22, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Why is the pump cutting in so much
Check your water pressure tank air pressure, turn off pump, drain off all water pressure and using a air pressure gauge check pressure at the schrader valve on the water pressure tank. It should be 2 lbs below pump cut-in pressure, they come factory charged at 30 PSI...works for most residential systems. Most likely you have a bad bladder in pressure tank.
Other possibles are a broken line between pump and pressure switch/pressure tank or bad pressure switch.If you have a pressure gauge on the water system(should have one near pressure switch) see if it is cycling at the right points if it is the switch is good. If pressure is dropping with NO water uasge in house you have a leak.
Most likely a bad pressure tank bladder is the problem.
Oct 24, 2009 | Jet Plumbing
Addie Water Systems Metered Water Softener Logo
755 people viewed this question
Top Addie Water Systems Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you an Addie Water Systems Water Dispensing and Filtration Expert? Answer questions, earn points and help others
