Question about Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509
When a battery is connected the amps show and then goes right to flo eventhough the battery is not charged with a Stanly BC1509
2 Suggested Answers
SOURCE: I can't find a user
Go here for the Stanley BC1509 15 AMP Battery Charger Manual:
http://www.baccusglobal.com/stanley/bc1509.php
Posted on Jul 27, 2011
Why does the battery volt button show 12.1 v when the battery doesn't have enough juicy to start the car? I thought it would show me the volts the battery had
The meter shoes the battery voltage, not the amperage. It may have 12V but still not supply the current (amperage) you need to turn over the starter.
Sep 07, 2014 | Stanley 15 Amp Battery Charger -...
Amp Gauge goes all the way past the highest number
amp gauge, and you forgot high number, 30, 60 , 80 , 100 amps?
and did it go left or right, one way is discharge other is charging.
key facts all.?????
no year,
no statement of , if car is stock or not.
if someone added a gauge, here,
back in the olden days, before the way better volt meter.
they had Amp gauges, many we ADD on.
most are wrong size. too. and installed WRONG. (ask correct way)
if the alt dies, the ammeter goes negative amps showing disgnarge ammount,
when runing right it ill be in the posative direction, charging battey
or at 0amps, battery is charged.
all this depends on how its installed.
if put in the alternator lead (big) it will only show alternator output.
10 to 50amps, 10 is typical. 50 be dead battery, running.
Feb 23, 2014 | Jeep Cars & Trucks
Owners manual for stanley battery charger
whats wrong with it? if you want a manual search google.
Mar 05, 2013 | Stanley Black & Decker Stanley Bc1509 15...
Can I charge a Polaris battery at 2 amps to keep it charged?
use a small solar panel ,cheap and it will keep the battery up
Nov 09, 2011 | Stanley Black & Decker Stanley Bc1509 15...
I can't find a user manual for stanley 15 amp automatic battery charger BC1509 no matter where I look. Can you help??????
Jul 15, 2011 | Stanley Black & Decker Stanley Bc1509 15...
Just want to know what the code FLO stands for kid lost the manual
The digital display shows "FLO" to indicate that the unit is in float charge mode. The battery "fully charged" icon will display on the LCD screen and the arrows pointing to the "+" and "-" will flash. In this mode, the unit monitors the battery voltage and charges as necessary to assure the battery maintains full capacity. The unit remains in float charge mode as long as the charger is connected to the battery and plugged into a functioning AC outlet. I hope this has answered your question.
Apr 01, 2011 | Stanley Black & Decker Stanley Bc1509 15...
Charges ok, battery was replaced, connections cleaned and painted,ran fine for almost three months, then battery went flat again, checked altenator clleaned and greased connections, van ran fine for any...
I would check and clean any wire and connection between the alt and the battery and all grounds. Also check and see if charging voltage is the same at the battery post as it is at the lug on the alt.
Feb 20, 2011 | Chevrolet Venture Cars & Trucks
1985 Ford Bronco.....alternator will not charge the battery. Replaced battery, alternator, voltage regulator, starter relay, and have completely cleaned all wiring associated with the battery &...
most older vehicles has have external regulators, plug in regulator before batt is connected or you will fry the reg. also maybe an ignition feed wire to the reg thta is not connected. sta and flo connections go to ext regulator.try this hope it helps--did have trouble with a mustang i was wiring one time. dave
Sep 18, 2009 | Ford Bronco Cars & Trucks
1989 s10 4 3 4x4 blazer the amp goes down why
Sounds like loose or faulty Alternator connection try cleaning and retightening cable connections. also check that battery connections are clean and tight. GL
Jun 09, 2009 | 1989 Chevrolet S-10 Blazer
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509 Logo
113 people viewed this question
Top Stanley Black & Decker Car Audio & Video Experts
xxxxxx xxx
Are you a Stanley Black & Decker Car Audio and Video Expert? Answer questions, earn points and help others
