I installed a new netgear router r1600 and my link light on the modem is now blinking yellow. Why
Why would my link light on my modem start blinking yellow after putting in a new router?
5 Suggested Answers
  • 3 Answers
SOURCE: Ethernet Port failure new router
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Posted on Jul 14, 2008
frcs68
  • 1605 Answers
SOURCE: replace netgear CG814WG with WGR614 Possibile???
CG814 and WGR614 both are wireless modem, with 4 LAN port.
the difference is CG814 use so call "stateful" packet inspection, where WGR614 is using NAT, which is less secured, and easily attacked.
both have spam filer, and you can set restriction as to what website or content of the website.
CG814 should cost more than the WGR814. you should ask the resaller for the difference.
Posted on Feb 09, 2009
babes_ganda0
  • 381 Answers
SOURCE: router or modem problem
hi..try to resets the setting of router or try to open the setting of router using/type this #>192.168.1.1<thanks and good luck..^_^
Posted on May 15, 2009
rcirone203
  • 70 Answers
SOURCE: trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Posted on Jul 16, 2009
My modem use to blink green now yellow?
Well I would need more info for one. But typically it could be just a a change in the lights. My old router had green lights my new router has blue lights.
Feb 27, 2014 | Computers & Internet
Netgear wnd3700v3 has two yellow linght on and no internet
The internet port of the router needs to connect to the modem from your ISP. The two yellow lights are normal but if the internet light is off check the cable from the router's internet port to your modem.
Sometimes the modem needs to be turned off then back on again for the router to get an internet connection (IP address).
Nov 16, 2013 | NetGear WGT624 Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Router not working, blinking wireless light, no internet light
Probably, this is because of Firmware Issue, There are firmware updates for most of netGear routers and they have to be done.
If you do these updates, you will have to write down all details of you networ/router manually and once the update is complete, you will be manually setting up the router,
IF you have the netgear support no. and your router is still in warranty, contact netgear and ask them help you do these updates..
the website with the updates are
http://kb.netgear.com/app/products/family/a_id/1297
Jul 03, 2010 | NetGear WGT624 Wireless Router
Cannot connect to internet using wgr614 router. connection is good without router. with router connected, internet lite blinks.
To use a router with a DSL modem or cable modem, you need to connect the modem to the router at the WAN port and then connect the PC to one of the router ports. If the cable you have been using between the modem and PC is lableled as a cross-over cable, it is the wrong type of cable for the router connection. Use a straight through cable to connect the modem to the router.
If you do not have a manual for the router, here is a link to the router manual online: http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
The cross-over cable could be the problem (typically yellow cable).
Jan 20, 2010 | NetGear WGR614 Wireless Router
Blinking light on NetGear FS108
One LED is a Link light that will blink on activity.
The other shows link speed.
These boxes have AutoUplink negotiation so no crossover cables are required.
Test again with a standard straight though ethernet / CAT5 cable.
Mar 19, 2009 | NetGear FS108 8-Port Ethernet Switch
Netgear router
First I need to know the following infor to provide you some solution to your router problem;
Internet Service Provider:
Modem Brand Name:
Laptop Model Numbe:
Laptop OS:
Jul 30, 2008 | NetGear RangeMax WPN824 Wireless Router...
Router stopped working altogether
Please check your cable connections; are the lights blinking? try connecting your computer directly to the modem dsl port that is connected was to the router if connection can be restored.
Nov 11, 2007 | NetGear WNR854T Router (WNR854T100NAS)
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
