Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer stays on five seconds and cuts off. Then it keeps beeping
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Jan 20, 2016 | GE Refrigerators
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Is there any way to silence the sounds these machines make when you turn the selector knob or push any button
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 19, 2015 | Maytag Maxima MGD9000YW 27" Front-Load Gas...
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
Jul 07, 2014 | Frigidaire Refrigerators
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Where is the resset buton on frigidaire electric dryer machine?
  1. Press and hold the "Control Lock" button for five seconds to lock the dryer. Release the button when the dryer beeps, indicating that the dryer is in locked position.
  2. Press and hold the "Control Lock" button for five seconds to release the lock.
  3. Press and hold the "Options" and "Select" buttons at the same time on Frigidaire dryer models that do not have a "Control Lock" button. Hold the buttons for 10 seconds until "LOC" is displayed.
  4. Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.
  5. please comment on these by telling how helpful.
Dec 20, 2010 | Frigidaire Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
35 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
