Question about Infinity BASSLINK Car Subwoofer
I have an infinity bass link along with six other speakers on my boat, can I add another amp just so the cockpit and tower speakers run off one amp and the basslink powers it's self
I want only bass coming from the sub and the other amp powering my mids
Benimur
  • 6966 Answers
SOURCE: no power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
Posted on Nov 01, 2007
DrElectrics
  • 199 Answers
SOURCE: Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
Posted on Feb 13, 2008
zzedly
  • 300 Answers
SOURCE: Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Posted on Mar 20, 2008
  • 3 Answers
SOURCE: Infinity Bass link keeps cutting out.
Tapping into front or rear gets high level signal 3 plus volts at low impedance which is totally unsuitable for the sub's line level input which is more like 300millivolts > A competent tech could make up an attenuator patch or just take it to a professional car installer before you do more damage
ataraxia
Posted on Jan 16, 2009
SOURCE: Infinity Bass link has no power. Both fuses are
what the problem is that you have a bad ground one way to tell is run the ground to your battery ground and i bet you it will work it happens all the time
Posted on Apr 17, 2009
I have a pair of linn komponent 104 speakers i was wondering if i can add a sub woofer to my amp to give the sound more bass as the speakers dont have a good bass sound
The Linn's should have a good bass, clean & tight but not boomy. Have you got them correctly phased? Red-to-red, Black-to-black? Bass is killed if one speaker is anti-phased.
Nov 11, 2014 | Car Audio & Video
My cars battery died, and when i turned the car on finally the head unit and my infinity bass link didnt turn on
Check the fuse in your car's fuse panel. If it is burnt then change. If it is still good, check the fuse on the head unit and amp.
Sep 03, 2012 | Infinity BASSLINK Car Subwoofer
Hi i just got 2 new infinity 860w reference 8'' subs 250 rms each and pushing it with sony 600watt amp pushing it but very low sound and no bass why the othier speakers i have in 10'' hit the bass fine but...
The amp may no thav eenough to push these subs, these are top of the line subs, they probably require a bigger amp, if you are running other speakers through this also, you certainly need another amp, or a bigger one with more channels. also double check all your wiring.
Mar 29, 2011 | Jl Audio 12W7 Car Subwoofer
Convert Infinity RS2 (old towers) to bi amp
Dont do it they are not designed for this.
Jul 17, 2010 | Audio Players & Recorders
My infinity reference 7540a amp cuts in and out with heavy bass when the ''loud'' feature is on. I redid my ground, remote wire, shortened my power cable, and double checked all speaker connections. I dont...
sounds like ur gains are set to high and is going into protect mode
also what ive seen happen before is the speakers (if mounted in metal shelf or door and arnt bolted down correctly can flex under bass notes and flex the speaker that much the termanls short onto the metal and amp hits protect mode
(rare but worth a look if you think u have elimanted most other things Had a dude come to me when i was working in sydney with this problem )
also could be things like clipping protection , overheat protection ,amp drawing to much current from the alternator
do your lights dim when you hit the bass notes ?
get back to me and im sure we could solve this problem
Jan 22, 2010 | Infinity Reference 7541a Car Audio...
Infinity 6100m Microphone Replacement parts accesories
Ours broke and the only other place we could find one was from the dealer and it was even more expensive. Do your tower speakers still work without the mic?
Jun 15, 2009 | Infinity Inifinity 6100M Ski Boat Tower...
Apr 17, 2009 | Infinity BASSLINK Car Subwoofer
ataraxia
Jan 15, 2009 | Infinity BassLink II Car Subwoofer
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Infinity BASSLINK Car Subwoofer Logo
71 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
