15''lcd monitor cable problem.
I need help with the dixons 15''lcd monitor,model:f159.
vga cable problem.
the problem is at the end of the connector socket where it conneted into the pc.the connector socket is missing.i would like any help if any one knows which colour goes to which pin on the 15 pin connector.
the wires colour are:
pink,black,clear,white,green,blue,yellow,orange,purple,silver,copper.
    Problem Solver:
  • 6 Answers
Hi, this may not be solution for what you ask but rong signal can or mayset u monitor on flames it hapined to me, why? hold on to old cable whan you can go and get new one, if you say you cant find, then get a moltetester chack the each ends pin to pin for contanuity. good luck
Posted on Jun 22, 2009
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
Hello, We purchased one of your projectors and someone stole our cable for it. i would like to know what kind of replacement cable i would need to purchase. On the box it says. PJD5122 i dont know if that...
Hi!
The cable you need for your projector is a common D-sub 15 pin to D-sub 15 pin VGA cable.
It is the same kind of cable used between a PC and a LCD Monitor, with the same type of connector on both ends: VGA D-SUB with 15 pins. (so you can use one of those monitor cables)
Please let me know if it helped.
Best regards!
Aug 09, 2011 | Office Equipment & Supplies
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
What kind of video cable/connectors do i need
VGA cable with DB15HD (15-PIN) male at both ends if your PC has VGA DB15HD video out, or DVI cable if you have DVI output on your PC video card.
May 02, 2010 | Liquid Video L17LCD2 17" Flat Panel LCD...
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Hi there, can any body help me.i need a onboard connecter cable for dixon's 15'' lcd monitor or the wire layout so that i can repair the cable at the vga connecter to the pc.just that i got the monitor...
I assume the cable is integrated into the monitor so it cannot be changed. VGA is pretty much standard regardless of who makes it. Here is a link to a diagram showing the vga pin outs. you should be able to match this and then repair it. http://www.theavguide.co.uk/view_page.php?page=18
Mar 18, 2009 | Computers & Internet
Connection
Your HP notebook PC probably has a VGA (aka HD-15) connector. Check page 16 of this PDF to make sure - connector #2 is the VGA connector.
Your Compaq monitor also has a VGA HD-15 connector, so it should plug directly into your laptop's port after unplugging it from the other PC.
You will still need to plug the Compaq monitor's power cable into a wall outlet for power.
If you are going to share this monitor between your notebook and the other PC, you may want to consider purchasing a Keyboard-Video-Mouse switch (known as a "KVM switch") - there are many different models - you will need one with VGA, and whether you need USB or PS/2 keyboard/mouse connections depends on what your other PC's keyboard and mouse are.
Apr 06, 2008 | Compaq TFT450 14" LCD Monitor
Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Apr 02, 2008 | Computers & Internet
Computers & Internet Logo
176 people viewed this question
Alun Cox
David Payne
David Payne
