Question about InFocus X3 DLP Projector1600 ANSI Lumens, Supports1280 x 1024 SXGA Resolution2000
MY PROJECTOR INFOCUS X3 FROM COMPUTER THE IMAGE IS TINTED RED LOOKS GREAT THROUGH RCA JACKS USING DVD PLAYER. I HAVE RELOADED FIRMWARE AND RESET TO FACTORY SPEC.'S WITH NO CHANGE IN OUTPUT
  • 2,237 Answers
Make sure you're on vga and not component input. it's a dlp (there is a colorwheel), so no bad lcds.
Posted on Aug 17, 2009
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
Everything is yellow! It was working fine a week ago but when I went to do a presentation yestereday everything is yellow??? I tried adjusting the colors and I tried a second computer but yellow
hello,
what this indicate from the color display on the system mean that the display sensor (lens)in getting weak it need servicing or a replacement, to to this servicing you will have to unscrew (open) from the stroll then clean up the lens with little spirit solution on the surface with care allow the solution to dry up it self then reset the programming on it please while doing this you will have to be very careful with the wire connection around ,but if this fail then you will have to get a replacement on it
This are recommended fix is to replace the lens. You can generally find replacement parts at these websites:
www.projector.com
letsgodigital.org
comforu.com
technabob.com
techshout.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing a lens is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own
thank you and thanks for you sing fixya.
Jul 01, 2010 | InFocus X3 DLP Projector
InFocus LP540 Red Tint
first swap out the source cable. if the problem persists, reset the settings to factory default. if the problem still persists, your colorwheel may be bad.
Oct 29, 2009 | InFocus LP 540 Multimedia Projector
Infocus 540 has a blue tint to it.
if it only has a blue tint when the computer or video is hooked up, reset the settings to factory default and replace the cables. if the splash screen (when it says "infocus") has the blue tint, one of the light filters are fried due to excessive heat and dust. unfortunately, you'll have to replace the entire optical engine.
Oct 08, 2009 | InFocus LP 540 Multimedia Projector
Infocus 4805 color mostly red when using componant cable
This problem can be caused by several things.
Most commonly a poor connection involving one of the rca component connectors or a failure involving the component output of the source.
However what also works like magic is to press the auto image button that's on the projector itself and it will re-sync / re-define correctly the component source and presto it looks good again.
A power brown out can cause this to occur and a simple "auto image" reset will fix it!
Good Luck!
Jan 09, 2009 | InFocus ScreenPlay 4805 Multimedia...
Colors showing red on screen
Hi Stella,
There is a button on the projector called "Auto Image"
Most people don't realize it's even there.
Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
Note: this feature is nowhere in the menu(s)
Good Luck!
SagerTronics
Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Black and white image on infocus x3
first reset the settings to factory default (menu, settings). if that changes nothing and the colorwheel is still in tact, the main board is bad.
May 07, 2008 | InFocus X3 DLP Projector1600 ANSI Lumens,...
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
222 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
