Question about Toshiba Satellite Toys
WHAT DOES ATM ERROR CODE 3-DA0 15(00) MEAN? - Satellite Toshiba Toys
What is error code 8071053c
Search Results
    8071053D Error Code Fix PS3 - YouTube
    ? 0:59
    https://www.youtube.com/watch?v=t4swvgXy3ak
    Apr 5, 2011 - Uploaded by IDOC1210
    This is an explanation of what the error code 8071053D is on the Playstation 3.
Oct 24, 2015 | Office Equipment & Supplies
My honda 2007 pilot engine light comes on atm light it say what does that mean
What OBD Codes are present & what does it
say on the internet, when you look them up ?
Sep 30, 2014 | 2007 Honda Pilot
What is meaning of this ATM error
*7810*2*E*300050900,M-13,R-10110
what is meaning of this error codes and whats happening for atm machines
Jul 19, 2013 | Summit Appliances Division Youniverse...
Ncr atm error codes
Contact NCR Support. They should have the answer to this problem. That is a proprietary piece of equipment.
Jul 19, 2013 | Computers & Internet
Start over with money
Here is a link to the PDF Instruction Manual. I have also copied the instructions for resting the amount to zero:
To Reset Account To Zero:
Turn on the ATM Safe by inserting your ATM card into the slot and entering your PIN code.
• Press and hold the 1, 2, and 3 keys (Fig 8).
• The display will read, "Reset to zero?"
• Release the 1, 2, and 3 keys and then press the "e" key.
If the electronic functions of ATM Safe stops working, open the battery door
(see instructions "To Install Batteries") and locate the RESET button above the batteries.
Press once to reset. Note: Account balance will not reset to zero.
Jan 25, 2011 | Wild Planet Room Gear Atm Safe Bank
I have a problem in my ATM machine.. it shows the error on screen ( communication down) i check my telefone lines its ok ..... and there is no problem in brain net connection ..... plz some one help me...
Different ATM Machines have different error codes. If your ATM machine is experiencing a communication failure it could be a bad modem board, or just a simple phone line problem.
I suggest starting with replacing the phone line. First, plug a regular phone into the wall phone jack, make sure you have dial tone. If you do, get a brand new phone cord and run that into the top of your ATM. Disconnect your ATM phone line inside the head of the ATM and plug that new cord in there. Try and clear the communicaiton error. If that works, try a transaction. If that works, replace old line with this new one.
If that doesn\'t work, make sure you didn\'t lose master keys, and that your ATM is actually online with your processor.
If you are not getting good service, and your ATM has been down for days, you should look into changing your ATM processing.
Google ATM Processing or call 888-501-5246
Dec 05, 2010 | Computers & Internet
Forgot PIN
Answer: 1. Insert your ATM card into the slot with the holes pointing down
2. The auto teller will ask you to enter your PIN code.
3. Press and hold keys 1 and 2 until the screen reads, "Reset PIN."
4. Enter a new four-digit PIN code, and then press the "e" key.
5. Enter your new PIN code again to confirm. Press the "e" key.
6. The ATM Safe will restart.
Aug 08, 2010 | Wild Planet Room Gear Atm Safe Bank
I keep getting this error code:80710102
If its a dns error restart ur router or wireless box
if it says its logged you off psn the server is down atm
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
PS# console error code 8001050f
PSN is doing repairs ATM there is nothing you can do but wait
Toys Logo
46 people viewed this question
Top Toshiba Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toshiba Toy Expert? Answer questions, earn points and help others
