Question about Kitchen Ranges
JUST REPLACED A BURNT OUT BAKE ELEMENT WITH NEW ONE FROM DEALER IN MY MAYTAG ELECTRIC RANGE PRECISION TOUCH CONTROL 700...NOW IT WON'T PREHEAT....IS THERE A FUSE AND OR SOMETHING ELSE I SHOULD BE LOOKING AT TO FIX....
  • j_joyal Jun 22, 2009
    i checked the connections they appear to be tight and are not loose..
    President:
  • Kitchen Ranges Master
  • 2,923 Answers
There is a bad connection inside the electric range. The most common place is on the terminals of the bake element.
Hope this helps and have a great day!
Posted on Jun 22, 2009
  • Melvin Ramos
    Melvin Ramos Jun 22, 2009
    Thank you for the response.
    Since everything's properly connected, you may need to check the EOC (Electric Oven Controller). Sometimes, the EOC is killing the power to the element.
    You need to have a meter so that you could also check if there are parts of the circuit that is not sending voltage to the element.
    These are the things that you need to check.
    Have a good one!
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Dec 26, 2012 | Frigidaire FEF352 Electric Kitchen Range
When i turn on bake it goes to preheat but nothing happens. the broiler and top burners work fine
If a gas range, you have a defective ignitor,
If electric, you have a burnt out back element
Jul 29, 2010 | Frigidaire FGFL79GC Stainless Steel...
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When set to bake oven does not preheat and tempature does not increase. when set to broil oven heats
Since your oven has a separate element for bake and broil I would bet the bake element is burnt out or burnt electrical connection to the element. Make sure you disconnect all power to the range before checking.
Mar 21, 2010 | Amana AER5844VAD / AER5844VAB / AER5844VAW...
Hi ,I have model jgs8850ads,it takes along time to preheat,about 40 min. what could this be? please respond.
is this a duel fuel with an electric oven..... the bake is the bottom and the broil is the top both cycle on and off to preheat the oven.... if ur lower bake element is burnt out then u woould expereicnce the problem u stated..... if u have a gas oven then ur ignitor or glow bar is probably burnt out....... either way it sounds like your bake element or bake ignitor has failed
Jan 31, 2010 | Jenn-Air JGS8850ADS Gas Kitchen Range
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
