Question about Pool & Spa
Seal replacement hayward sp5615cp - Pool & Spa
Hayward pool pump leaking from underneath motor
The leak is an indicator the shaft seal has failed. It leaks by design to let you know to replace the seal before water gets into the motor and ruins it. Replace the seal right away.
Aug 17, 2014 | Hayward 3/4hp Super Pump Inground Pool...
I replaced emerson 1hp pump to my hayward max pump and leaks any ideas all seals replaced
Hi, this is John the Hayward tech. Sounds like the mechanical seal is leaking. If you replace the spring loaded seal the problem could be that it was installed backwards. It is ceramic against carbon. if installed the other way it will leak. Any debris or oils getting on the seal will also cause it to fail Running pump without any water will heat up the seal and cause it to fail.
Jul 21, 2014 | Hayward Pool & Spa
Sp5615cp
Hayward is junk. Go with something else.
Jul 14, 2013 | Hayward Pool Products Pool & Spa
Hayward sp5615cp
try turning armature on back when off then try again motor is going
May 09, 2013 | Hayward Pool & Spa
Leaking hayward regenx filter
if seal where leaking replace and lube seal if tank putty inside if unions replace or replace seals
Oct 02, 2012 | Hayward EC-40 DE Pool Filter with pump
How do you replace the seal on a Hayward pump model sp-1615-z1-mbk
if seal leaking probably ruining seals replace whole pump
Sep 20, 2012 | Hayward Pool & Spa
How to replace seal on hayward power flo matrix?
if seals leaking ruining bearings next to go replace whole unit
Jul 21, 2012 | Hayward 1hp Power Flo Matrix Above Ground...
LEAKING A SMALL AMOUNT OF WATER COULD THIS BE A SEAL?
ON A HAYWARD IT'S A TOSS UP, COULD BE THE SHAFT SEAL OR THE TANKS ARE KNOW FOR CRACKING. FIRST THING YOU CAN TRY IS REPLACING THE SHAFT SEAL .. LOOK ON EBAY FOR HAYWARD SHAFT SEAL WITH HOW 2. THE SEAL YOU NEED IS A 201. AND SHOULD COST AROUND 10 BUCKS. FALLOW THE INSTALL INSTRUCTIONS. OR YOU CAN TAKE THE PUMP APART AS FALLOW HERE ..AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY .. JAY
Jun 17, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Seal leaks on my power flo lx hayward pool pump
The seal can be replaced with either a 2131 or 200 seal from any pool store in your area. Most can offer tips on how to replace the part if you need guidance. The seal should be under $20 and could be as little as about $5.
Aug 21, 2010 | Hayward Pool Products Hayward Power Flo LX...
My Hayward pump is leaking.
is the pump leaking from the lid if so you may have an obstruction **** as dirt leaves or debree if the pump is leaking where the motor meets the wet end of the pump then you need to replace the ps1000 seal not sure if ps1000 will work on hayward but when you go to buy one. tell the pool store employee that you need a ps seal for an hayward.
Apr 28, 2009 | Hayward Pool & Spa
Pool & Spa Logo
55 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
