Question about Canon ImageRunner C1030if Copier
Why does my canon 1030if say "no letter in stack bypass".
4 Suggested Answers
  • 37 Answers
SOURCE: Canon Imagerunner 330s - Stack Bypass
you can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Posted on Feb 05, 2008
checkitright
  • 1362 Answers
SOURCE: STACK BYPASS option causes LOAD PAPER message & no print
1-did you change to bypass instead of trays in the menu?
2-the sensor (black lever in the bypass that triggers the sensor) is missing or bad
Posted on Oct 09, 2008
babaprithi
  • 372 Answers
SOURCE: I am using a canon
in the copy settings in additional functions there is standard bypass settings.change it from there
Posted on May 24, 2011
My Canon IR1610 is giving wrong paper size message when i used legal size paper(8 1/2 x 13) but it does work on letter size.I did change the value by pressing additional function and set it to LegalR.It...
u have to choose freesize from the bypass tray and then measure ur paper and enter the size in XY.then only u can use it and that too from bypass tray only
Jul 11, 2011 | Canon Office Equipment & Supplies
I cannot print from the Stack bypass tray. I have tried many adjustments. This leaves me unable to print envelopes and using letter head. What could be wrong?
First of all select the paper select button for the bypass tray on the control panel after putting envelopes in the tray. It will then say select paper size. Press the RIGHT arrow until COM 10 or executive comes up and the select OK. Then print what you want . You have to look at the printing properties on the driver to make sure you have auto or the bypass tray selected
May 10, 2011 | Canon imageRUNNER 1023iF Black and White...
On a Image Runner 1023iF trying to print letter envelopes loaded in the Stack Bypass. Machine once it received the print job just beeps and flashes.
Hy,
did you select the correct paper size on machine display? When you put paper in baypass the copier ask you for paper size and type.
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Where is the stack bypass for canon NP 6230?
pull down the upper right side cover of the machine,thats the bypass tray
Jul 05, 2009 | Canon NP 6230 Copier
Oct 09, 2008 | Canon imageRUNNER 400S Copier
Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Sep 30, 2008 | Canon imageRUNNER C3200 Color Printer
Canon ir 2200 print from oracle
ive had this before its under your printer setting tools you have to set that copier for tray 1 or letter turn off automatic
Sep 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Jan 29, 2008 | Canon ImageRUNNER 330s Copier
Canon ImageRunner C1030if Copier Logo
35 people viewed this question
old marine
old marine
