Question about Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer water won't drain out - Whirlpool LSR5132PQ Top Load Washer
  • 6,784 Answers
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 22, 2009
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Calypso Washer no draining
Did you get the tests done??
Posted on Jan 27, 2008
jsrock516
  • 5911 Answers
SOURCE: Drain problem
If there's water in the drain line this is normal. There is roughly about a half a gallon of residual water that remains under the wash basket, drain line and drain pump combined. That's why it is important to leave the washer door open when not in use to allow the tub to air out. It will not evaporate the water, but will help reduce the build up of mold, mildew, and odors.
Now, if you look inside the wash tub and see standing water, then you may have some drain line issues. Make sure your drain line does not exceed 10 feet in length. Excessive lengths can cause backwash. Also, make sure the standpipe at the wall is at least two inches in diameter, a minimum of 34 inches from the floor and does not exceed a height of 72 inches. All these conditions can cause slow drain problems and/or backwash.
I hope this answers your question and that you find this helpful. Please post back if you need further assistance.
PS Make sure the standpipe is draining properly. It should be capable of draining approximately 17 gallons per minute.
Posted on May 28, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
washdryman
  • 154 Answers
SOURCE: Whirlpool /Roper washer won't drain or agitate.
LID CONTROL SWITCH BAD
Posted on Feb 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washer will not drain water out
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Washer won't fill water runs out bottom
either you have a bad drain hose or the drain pump has a bad seal behind the outer case
May 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Why won't washer drain/spin or allow me to open the door?
Hello Micheal,
The problem is going to be bex=cause the water didn't drain. This tip i wrote explains how to make it drain http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My washer will not drain. At first it was giving the normal error messages like LF, so we had the drain piped to see if it was clogged. Now the washer fills up and does not drain. I have a Whirlpool...
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Whirlpool Washing Machines
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Whirlpool LSR5132PQ Top Load Washer Logo
295 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
