Question about E-Machines (T2958) PC Desktop
New batteries in but camera doesn't turn on. Any suggestions would be a help, cheers Rua
  • ruas Jun 22, 2009
    Sorry Canon PowerShot A610 and yes it is plugged int my PC but nothing from the Camera?
  • ruas Jun 22, 2009
    Absolutely first class. Cotton swab worked THANKS HEEPS Ekse. where do I add my 4* rating?
  • E-Machines Master
  • 13,433 Answers
What kind of camera is it? could you post its brand and model? have you tried connecting it to the computer, any life out of it?
Posted on Jun 22, 2009
  • Ekse Jun 22, 2009
    check that the batteries are inserted properly and are in the right way. Also try cleaning the battery contacts. For example with the eraser end of a pencil.
  • Ekse Jun 22, 2009
    Troubleshooting Power Issues.
    Please confirm the following items if the camera does not work even if you pressed the <Power> button.
    Cleaning
    the battery terminals with a cotton swab if the terminals are dirty,
    and then re-inserting the battery several times may correct this issue.
    Contact failures may have occurred between the camera and the batteries.
    Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
    Confirming that the batteries are properly inserted
    If the batteries are not properly inserted, the power of the camera will not turn on.
    Confirming that the [Memory Card / Battery Cover] is securely closed
    If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
    Close the [Memory Card / Battery Cover] securely, and then turn the power on.
    follow the instructions on this document to check that the batteries are properly inserted.
    http://users.turkuai.fi/users/niohtone/d...
    You will need a pdf reader to open the file, if you don't have one or you can't open the document get one from here: http://get.adobe.com/reader/
New batteries put in but L810 camera says battery low and then turns off
hello,either your 'NEW' battery's are not as new as you had expected,or you have either a camera or the main power input terminal's broken,corroded (due to a previous leaky battery)or have what is known as 'DRY SOLDER' joint's,and are impeding the current flow, have your camera checked by an electronics workshop,hope that helps, cheeres.
Apr 03, 2013 | Nikon COOLPIX L810
My canon powershot a2000is displays 'change the batteries' even when the batteries are new and completely charged. i am not able to click more than 3-4 pics. these batteries work fine on other...
You most likely have dirty contacts or a loose connection inside the camera.
It might be worthwhile trying to clean the contacts. I would suggest using cotton wool twisted onto a skewer or wooden toothpick. Do NOT use any solvents or other liquids. If that doesn't help then you should seek professional advice ina camera shop.
Sep 17, 2011 | Canon Powershot A2000 IS Digital Camera
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
My kodak easyshare V1003 camera will not turn on. It worked a few days ago and now it will not charge or turn on. I just bought new batteries and it still will not turn on. Any suggestions on how to fix...
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 09, 2009 | Kodak EasyShare V1003 Digital Camera
Fuji digital camera
I think I've solved the same problem on a Finepix A350. My shutter has been sticking for months now on powerup. I brushed all round the periphery of the shutter with a perfectly clean, small, camel hair brush and now it operates perfectly! So maybe the answer is to keep a new brush specially for this. Hope this works for you! I certainly would not try dropping the camera as someone suggested.
Jul 16, 2008 | Fuji FinePix A345 Digital Camera
The lens are out, and the camera won't turn on
Having taken apart a number of digital cameras I know they are fiendishly complicated inside. I can only suggest that you double check that the batteries are installed the correct way round and that you try again with new ones straight out of the packet.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Jul 13, 2008 | Samsung Digimax S500 Digital Camera
Vivicam 8400
I have a ViviCam 8400 and have the same problem UNLESS I buy Duracell Power Pix or Energizer Titanium batteries. These cost more than the regular grade AA batteries, but when I used brand new regular batteries, the camera would turn on for 2 seconds then turn right off. Titanium or Power Pix batteries make the camera work fine. And, because they are made for digital media, they do allow you to use the camera for longer periods of time.
Jun 09, 2008 | Vivitar ViviCam 8400 Digital Camera
E-Machines (T2958) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
