Question about Dell F3534 Touchpad
My Dell inspiron 1525 says "plugged in. not charging"
It use to happen alot so i just wiggles the charger and it worked not it dosnt seem to work at all, is there any simple soloutions as most of the soloutions i have reserched says to buy a new battery or charger which is expensive for me.
I had exactly the same problem. I got onto Dell support because my Inspiron 1525 was still in warranty and they told me to update the Bios which I did. That was nearly 2 months ago and I haven't had the problem since and it was a daily occurance.
Posted on Jul 07, 2009
I had the same problem I just updated the BIOS and now it's charging. Try this it worked for me. Download the update from Dell's website you need at least 10% charge on the battery for it to run after you download. Get your service tag # from the bottom of the laptop and plug into Dell when you go to download to get pointed to the correct update. BIOS update works!
Posted on Jun 10, 2010
What you need to do is,
Take the battery out for a few minuits. Then put it back in and start the laptop again.
If that doesn't work, turn your computer off and then turn it back on again and hit F2, then reset settings and that should make your settings on your charger "Plugged in and charging"
Posted on Aug 19, 2009
  • Dell Master
  • 2,404 Answers
Sounds like your dc jack may be loose. If you can take it a repair shop they would need to take out the motherboard and resolder the connections to the dc jack, then at that point you can plug in your adapter and it will charge properly. As far as cost is I'm not sure but I feel that your ac adaptor is good, if you can try another known working battery then try that cause you still might have a bad battery and if another one works then problem solved.
Posted on Jun 25, 2009
My laptop is dell inspiron 1525 but battery is not charging i have replaced the battery and even i have used new adapter but i cant solve the problem please help me to fix it
Hi
please remove the battery, plug-in the charger and turn ON the laptop, if it doesn't work,
then the internal part that connects the laptop to the charger have problem and need to be fixed through a technician.
Good Luck
May 13, 2011 | Dell Inspiron 1525 Notebook
I've recently bought a new charger for my dell inspiron 1525. The green light still shines when its plugged in, but it doesnt appear to be charging the laptop itself. Before, i would have put it down...
enter the bios with F12 and battery status somewhere, you have to see if the battery is charging.
1 - if you do not recharge the battery, you can try a new battery if the battery schimnabata no (new) option 2 then it does not load.
2 - is necessary to change the motherboard, because the battery charging mode does not function normally.
warranty if you go to them to do.
Feb 12, 2011 | Dell Inspiron 1525 Notebook
Have a dell inspiron 1525 that will no longer charge, replaced battery, charger and power adapter card in laptop. What can problem be - read that it can be some capacitors. Where are they and how do I...
Tom
i have inspiron 1525 as well ... if the computer wont boot up, then the mainboard may have experienced a power surge of excess current. did you have t-storm or power out while your computer was plugged in with Ac adapter ?
if not , to answer your question, the capacitors you inquire about are so small, it would require special solder machine to replace these CAPACITORs, as they are very tiny in size and require absolute temperature (heat) from solder gun to pally appropriate solder to replace the capacitor(s).
i think your mainboard is gone.
if i can be of further assistance, please let me know-- i can help
Nov 02, 2010 | Dell Inspiron 1525 Notebook
1525 dell battery not charging.
this could be one of 3 things.
Bad battery
Bad AC power adapter
Bad internal power jack (where the plug goes into the laptop)
The easiest thing to do is to try and use your laptop with the ac power adapter plugged in and no battery. This should work but if it doesnt then you know it probably is your ac power adapter. But if you feel like you have to wiggle and hold the cord in then it may be the jack on the inside. The only way I know how to fix that is to take it apart and resoder the joint holding that part together to make a stronger electrical connection.
As for the battery if you let it sit out for a day it will discharge any current it currently has inside of it and then you can try again to charge it. If that doesnt work and your cord and jack seem fine then you will need to look for a new battery to replace the one that died. This happens over a couple of years as the battery life shortens over the life of the laptop and more so if you use it heavily.
May 07, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Plug in for the charger got damage
I work repairing laptops every day and the number of laptops i see about 5 or 6 cases of this every week, i sell universal chargers for laptops but they don't work 100% with dell. they will power dell laptops but they won't charge the battery. which end of your charger got damaged
Mar 08, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery quit charging when warranty quit. Bought new charger, didn't help. Told motherboard needs replacement? This seems fishy to me. What kind of laptop works longer than the...
It is possible the battery itself has wore out. They have a limited amount of time they can be recharged. Does the unit run while the charger is plugged in??
Jan 26, 2010 | Dell Inspiron 1525 Notebook
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
For some reason my Dell Inspiron 1525 wont charge!!. I plug it into the main and the green light comes on the charger lead and it is putting power into the computer but just not actully getting any charge...
This only mean that you have a failing battery and does not hold charge anymore.. battery life can last upto 2years, depending on how frquent you use..
HOpe this helps
Oct 30, 2009 | Dell Inspiron 1525 Laptop
Computers & Internet Logo
5,100 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
