Question about Kenwood KVT-512 Car DVD Player
Tiring to hook up my Sanyo ecd t1780dv player need the wire diagram
Lost my manual I need to hook up to my cabel box. plus what cabels i need for my dvw5000
here is a basic diagram of cable connection from a cable box to a vcr and to the tv.diagrams_hookup_tv_dvd_cabl.jpg diagrams_hookup_tv_dvd_cabl.jpg
Feb 06, 2011 | Sanyo DVW-5000 DVD Player/VCR
I have a Sanyo ECD-t1550 and the display is very faint. Any suggestions
might be cause its tilted upwards.. and the sun is glaring it.. try putting lower in your dashboard.
Jan 16, 2010 | Sanyo ECD-T1550 CD Player
How to remove the unit with the two long keys?
you remove the faceplate than the trim plate and than insert the two keys on eaither side of the headunit and than pull it out
Sep 12, 2009 | Sanyo ECD-T801 CD Player
Brake wire connection
usualy just needs to be hooked to ground, so the sanyo thinks the e-brake is on. If you want to do it the legal way, there will be a single wire pluged into the e-brake assembly, this wire will send out a ground when you pull the ebrake.
Aug 17, 2009 | Sanyo NV-E7500 Touch Screen Portable...
I have a Sanyo ECD-T801 CD player
try to wipe down the lens cuz probably when ur daughet put the penny inside it she may touch it so u can wipe with some Kleenex or something smooth then see !
Feb 07, 2009 | Sanyo ECD-T801 CD Player
My Sanyo ECD-T801 CD player isn't working.
Yep! That's your Problem. You will need to Remove the Head Unit and Remove the Top Cover and Try to Remove that Penny. Will not be Easy Depending on where it is at inside. Please Rate My Response! Thanks!
Sub
There is a sub preout on that deck, the light i belive if for when sub mute is on
Jan 03, 2008 | Sanyo ECD-T1550 CD Player
RCA Plugs
absolutely no.use a baby jack for your ipod
Oct 25, 2007 | Sanyo ECD-T8578 CD Changer
TUNING PROBLEM
Hi
Check for a little switch at the bottom of the device (You may have to take it out or remove some car parts first). You have to change it from USA to EUROPE. Good luck...
Chaim
Oct 25, 2007 | Sanyo ECD-T1560 CD Player
Kenwood KVT-512 Car DVD Player Logo
57 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
