Question about Goodman Manufacturing Goodman GSC130421 Air Conditioner 13 SEER Dry Charged 3.5 Ton
Why won't the compressor run
Compressor will not run
  • 4 Answers
This can be for a variety of reasons. It ranges from something as simple as no supply power (blown fuse, open breaker, faulty contactor, or run capacitor) or it could be more serious as a grounded or open winding in the compressor motor. My suggestion to any novice and or person without proper tools and knowledge; First check the low voltage (24 volt control voltage) by turning on the "Fan on" switch located on the thermostat to on, not "Auto" The blower fan should come on, indicating there's 120 volt and 24 volt available. Fan doesn't come on is an indication that there's no control power. The next step would be to check for power at the transformer and fuse located in the air handler. There should be 240 volts feeding the transformer, and 24 volts coming out. The control voltage is needed to operate the thermostat (which is the switch that sends the 24 volt signal to the compressor contactor to turn the compressor on/off. This 24 volt also powers other relays and switches in the system. knowing that 24 volt is available also tells you that the problem is most likely in the condensing unit (outside, where the compressor is located). At the condensing unit you should check for 240 volt supply power. Upon finding 240 volt supply power the question now becomes whether or not the thermostat is calling for anything (cool or heat if the unit is a heat pump). There should be 24-30 volt available at the small gauge wires feeding the contactor coil. While having the thermostat set at a temperature lower than the current room temperature (in the cooling mode) the thermostat should send a 24 volt signal to close the compressor contactor and turn it on. The non-metallic end of a screwdriver can be used to depress the moveable part of the contactor. After pushing in the contactor, should the compressor start then you may only need a new contactor. It may just hum because of a faulty run capacitor or grounded or shorted internal motor windings (grounded or shorted windings are usually indicated by tripped circuit breaker and/or blown fuse). It's a good idea to have a good multi-meter and knowledge of use before attempting any repairs or diagnosis on your own. I recommend some basic knowledge of electricity before even thinking about attempting any repairs or diagnosis.
Posted on Jan 25, 2015
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Compressor dosen't restart
replace capacitors might be going off on safety.
Jul 21, 2013 | Dometic Rooftop RV Air Conditioner
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
My model number 91965110 compressor runs but won't fill the tank
More then likely it is either in the valve plate (bad flapper valve or gasket) or the piston and sleeve have worn out which is usually from scoring. You will see that when you take the head off to inspect.
Aug 15, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Compressor motor runs but does not make compessed air
Some of the things for you to check are for any leaks anywhere, the valve plate assembly, the piston and cylinder assembly and the con-rod. If you have any leaks that let air out as fast as the piston is trying to pump it in you won't get any compressed air. Check the drain valve on the bottom of the tank and the air line from the pump to the tank. If any of the reeds on the valve plate assembly are bent or broken they won't seal the way they need to in order to compress air. If the cylinder is badly scored or the piston rings are scored or broken the piston won't pump compressed air into the tank. If the con-rod is broke the piston won't work at all.
Jul 25, 2012 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
A/C and heating core
The leaking heater core won't keep the compressor from working.
You say the ac system is charged, but the compressor won't come on ??
The compressor has to run to charge the system, otherwise you will only get half a can of freon to go in. The system holds 3 or 4 cans when empty.
The low pressure switch has to be jumped to make the compressor run to take the first two cans of freon.
Jul 03, 2012 | Chevrolet Cars & Trucks
I have a True GDM10 that won't cool. Motor runs normal, Evap fan is running, no ice build up, just won't cool. Is this a coolant problem and can a True GDM10 be recharged? See no hook ups in t
First let me ask, are you sure the compressor is running? If you verified that it was running by vibrations in the compressor area just know that the condenser fan can also cause those if your machine has one. The way to tell is if the compressor is generating heat. With that said, assuming that the compressor is running, and all applicable fans are running, you need to determine if the machine was losing cool over time or did it happen overnight? If the latter of the two you'll need to isolate where the leak is, be it the evaporator or the compressor area. To actually add freon to the system if no access ports are available you;ll need to get a piercing valve, I personally use pt# bpv-31 bullet piercing valves.
Jun 15, 2012 | True GDM-10 Refrigerator
Goodman Manufacturing Goodman GSC130421 Air Conditioner 13 SEER Dry Charged 3.5 Ton Logo
88 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
