Question about Electrolux Freezers
Electrolux euf23800 temperature problem increased from -18 to -10
I defrosted my Electrolux intuition chest freezer yesterday and the red warning triangle on the lid won't stop flashing now. Why?
Check the temperature inside the freezer, chances are it just is letting you know it hasn't reached the correct temperature yet.
Aug 11, 2016 | Electrolux Freezers
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Where is the thermostat on my electrolux freezer (E32AF75FPS)?
Hi spazmodius, thank you for your post! This particular model has a thermistor to relay the temperature inside the unit to the Main Control Board. The thermistor is located behind the evaporator panel, to the right of the evaporator. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Aug 03, 2013 | Electrolux E32AF75FPS Upright Freezer
My Electrolux upright freezer Model GLFU1467FWO Serial No WB61740462 ..the temperature warning light kept going off, so kept resetting it, now there is no temperature light at all, the freezer is stil
Check the condenser grille is clear and clean, and all fans are working. Get a cheap thermometer to keep in the freezer and check it from time to time.
Jul 21, 2012 | Electrolux Freezers
Why is the fridge compartment on my arthur martin ARA28285W8 always wet
It is not cool enough. Increase the cool by adjusting the thermostat switch.
Oct 04, 2010 | Electrolux Freezers
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
The temperature is increasing and even when put on 'super freeze', the temperature is not increasing just slowly increasing. The model number is 7462SNH1 Please can you give any idea of a fix. A couple of...
fully defrost unit with door open.do not use hot water.
load up with cold food and switch on the unit will take upto 24hrs to reach normal.poss cause ice around coils ...
Feb 11, 2010 | Freezers
Hi there. I have Electrolux freezer EUU 6174. The problem is that the compressor is switching on and off for 5 seconds and the temperature is to hight. I can't store any food in the freezer. can u help me?
your problem is likely the starting capacitor .. that is a metalic part (about the size of a fist) that is mounted on the compressor or near it .. it will have wires going to the compressor .. the capacitors are not very expensive and usually easy to change but make sure the unit is unplugged .. you can either write the numbers down off the capacitor or remove it and take it with you to a parts place to get a match ... take a photo or draw a diagram so you know where the wires go .(they usually just plug in) . .. you can order one from electrolux (might be higher price) .. dont allow the unit to continue running with the bad starting cap since the compressor can be damaged eventually ... if you call a repairman .. then make sure you tell him its a bad starting cap so he can bring one wiith him and avoild a second trip .. give him the model number and numbers off the capacitor if you can ... often the capacitor is actually two capacitors in one can ... one is for the compressor and the other is hooked up to the fan ... in that case replacing one would also replace the other ..
Dec 23, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Freezers Logo
80 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
