Question about Panasonic NN-T654SF Microwave Oven
Microwave dies after one minute
Panasonic NN-P794SFX - genius prestige worked fine for several years now suddenly after 1 minutes or so power fluctuates and shuts off before the end of set time. Warms stuff OK at times but then shuts off again (very few times error code H98. It is the power inverter. There is a brown Metallized film cap WHU 822J RATED AT 3.0kVDC outside body is cracked only but metal inside is fine. Could this be the problem.
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
SOURCE: Panasonic Microwave about 9 years old with
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on Jan 28, 2010
Testimonial: "Couldn't ask for more - response was prompt, helpful and clear. Thanks "
fathitkf
  • 1871 Answers
SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Apr 13, 2010
Daniel S
  • 4323 Answers
SOURCE: H98 code appear in my
Hi
H98 error code means high voltage diode failure and to solve this issue the inverter board should be replaced. Repairing Microwave is only recommended to be done by a professional just because of the voltage present inside the unit. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 10, 2011
Macmarkus
  • 2605 Answers
SOURCE: Panasonic genius prestige microwave oven
Hello, welcome to FixYa.
I understand based on your initial post you have Panasonic NN-SD797S microwave you are receiving the H98 error, correct ?
What this indicates according to the Panasonic diagnostic charts is as follow's below...
Newer Panasonic Microwaves have a built in fault codes....
they look like H97, H98....
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting.
H97, H98 and H99 are the codes provided indicating failure magnetron and inverter circuit problem areas. This appears in display window a short time after start key is pressed and there is no microwave oscillation.
What this means of course is the magnetron or inverter has failed...in my experience it is usually the inverter board and typically sells for around $100.00 - $125.00, I've also attached a link of your machines parts breakdown, item #32 on the second link.
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD797S/0789/0123245?pathTaken=&prst=0&shdMod=NN-SD797S
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD797S/0789/0123245/P0912074/00001?blt=06&prst=0&shdMod=NN-SD797S
I would shop around as I alluded to since it can be had for a lot less from one vendor to another.
I also decided to include a link here to a web page that has the error code meanings, flow charts to try and diagnos and other info you may find useful...**Please diagnos with caution and unplug the unit before removing any panels or attempting repairs...safety first**
http://www.applianceaid.com/micro_faultcodes.html#panasonic
Let me know how you make out and good luck. I'll wait for you reply and then help in any manner I can going forward if necessary.
Regards,
Macmarkus :)
Posted on Sep 19, 2011
Panasonic convection oven nn-cd989s, complete power off during prebake cycle of 450 deg which was directed to remove light oil coating from manufacturing process . Now unit has no power on face panel
Check the 20 amp fuse where the power cord ends inside the oven. If it is open check the latch switches. If the switches check ok the invertor is probably bad, smoking.
Dec 20, 2014 | Panasonic Genius Prestige NN-CD989S -...
Is there an on/off button for the turntable on the Panasonic NN SD997S microwave
If you don't see one on the control panel, then there probably isn't one.
Oct 17, 2014 | Panasonic Genius Prestige Nnsd997s -...
Stove top light on Microwave will not shut off.
There's a relay in the microwave that is not working.
Oct 01, 2014 | Panasonic Genius Prestige Nn-Cd989s -...
My micro wave door opens n does not shut tightly I guess and so takes about ten tries opening n shutting before it starts. What should I do Panasonic inverter microwave (the genius prestige) Model...
The door is either out of adjustment, the door switches are out of adjustment, or the door/hinges are damaged. If the door switch assembly can be adjusted to fix the problem, then make sure the door closes as snugly as possible. As any repair to a door can increase the amount of microwave leakage, which can cause possible health issues for you, it might be wise to, at the very least, have a technician do a radiation leakage test on the unit once the door problem is repaired.
May 08, 2014 | Microwave Ovens
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
My Panasonic Genius Prestige model microwave is in the "Demo" mode and will not operate. How to fix it?
RESET THE SYSTEM BY UNPLUGING THE MICROWAVE CORD FROM POWER FOR 30 SECONDS, CONNECT BACK TO POWER IF THE MICROWAVE CONTINUE WITH THE PROBLEM MAY HAVE A BAD CONTROL BOARD OR BAD ELECTRONIC CONTROL PAD...
Feb 19, 2011 | Panasonic NN-SD797S Microwave Oven
Pushing the start button trips the breaker. All functions seems to work, fan, clock etc but it just started as soon as you push start it trips the breaker. Control panel/board seems fine no burn marks.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Genius/Prestige/model.NN-P295SF
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Service manual below, troubleshoot with that. http://www.eserviceinfo.com/downloadsm/5734/PANASONIC_NN-K652.html
May 04, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-T654SF Microwave Oven Logo
59 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
