Question about Nuvo Essentia Amplifier
Trying to reprogram my Nuvo Essentia Amp, and I need to get the software in order to do so, and I am finding that it isn't available on their support site...
  • 382 Answers
Unfortunately it is only available to those who are certified installers/dealers. Nuvo tries to protect those that sell it and does not offer anyway to program it on your own (Unlike Russound that can be done through a keypad by anyone).
I wish I had a better answer but you will have to find a dealer/installer to get you a copy of the software.
Cheers,
Posted on Jan 08, 2010
I wish to cancel further orders of essentia high ph water. I am confussed and need help
SAD but this website can not assist you either . we do not know where you ordered from .to redirect you
Dec 07, 2015 | Pool & Spa
Nuvo Essentia won't power up
First, try unplugging all of the sound system and plugging the amplifier into an outlet on a circuit that was not changed by the electrical work. Also, plug an outlet tester into the outlet you were using for the amplifier to make sure it is correctly wired. If one outlet in a system has hot and neutral reversed and others don't, this could cause problems with some designs.
If you are lucky, dirty power from sparking inside the circuit breaker crashed the control circuitry in the amp, and it just needs a hard reset (power disconnect/reconnect) to be made functional again. In the worst case, something got fried and you'll have to use instruments to track it down.
Apr 23, 2014 | Nuvo Essentia Amplifier
Aspire 5515 Laptop/....A Microsoft bozo,.....(attempting to fix a virus but failed...gave up & ...) foolishly upgraded my Laptop to Win7 home premium..(without checking compatibility..) The Inter
http://www.driveridentifier.com/
I highly recomend you this freeware software since i'm pretty sure it can get you most of the drivers. However, in order for this tool to find the drivers you're looking for, you have to run it in the computer you need the drivers for.
if you can't get online with the computer, go to http://drp.su/drivers/notebooks/?v=Acer&m=Aspire%205515&id=11024&l=en and download the network drivers, get online, download the tool (first link), run it and download your drivers.
if you still can't get your drivers, reply this message telling me the problems you had and i will tell you how to make the windows vista drivers work with windows 7.
Sep 06, 2012 | Acer Computers & Internet
Nuvo Essentia low volume on left side speakers
check the wires make sure thay are not loose or partial connection
May 29, 2012 | Nuvo Essentia Amplifier
We have a Nuvo Essentia Six-Source, Six-Zone system. It plays the iPod fine, but the control pad says 'No iPod Detected'. This means I have to control the iPod from the unit itself, rather than being...
I had a few systems that did this but once I performed the latest firmware update it fixed everything.
If the combus on the ipod gets shorted then it will also do this. You have to disconnect the Cat-5 cable from the dock, unhook the ipod, reconnect the cat-5, then reconnect the ipod.
I would contact your installer and have him update the system for you, failing that re-do your connections on the dock. If that does not work you may have a deformed connector on the ipod that shorts the combus (had that once on a Russound system). Or a defective dock
Hope this helps,
Dec 24, 2009 | Nuvo Essentia Amplifier
Nuvo Essentia system on/off button flashes when keypad is plugged in. I can get 1 port in the back of the EZ Port to work on all zones but when keypads are plugged into other ports on/off button just...
You may have a pair of the cat-5 wires in the incorrect order which is causing a combus fault. Check all your cat-5 connections, ensure they are T568a (GS/G/OS/B/BS/O/BrS/Br).
Let me know if that checks out and we will continue trouble shooting.
Thanks,
Oct 29, 2009 | Nuvo Essentia Amplifier
Serial codes for nuvo simplese
I asked Nuvo about this and they said that the RS232 port was never setup for control, it is only to be used for programming when they are initially setup by Nuvo.
I have codes for the Essentia and Grand Concerto that I have written but non for the simplease as Nuvo said it cannot be controlled.
Cheers,
Nov 01, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Clock adjustment option not there
With the keypads go to menu, then setup, then zone settings, then display settings then time display. Will have to go to each zone to do this. The installer could have asked for your preference. Some people prefer it, some don't.
Sep 29, 2008 | Nuvo Essentia Amplifier
Nuvo Essentia Amplifier Logo
311 people viewed this question
Top Nuvo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nuvo Audio Player and Recorder Expert? Answer questions, earn points and help others
