Question about Coleman Heating & Cooling
Coleman evcon blower not working properly
I have an ac/heating blower made by coleman evcon and the blower does not want to shut off when ac shuts off , also there is not cold air coming threw 2 of my vents but the rest are working properly (when blower is on , when manually shut off the cold air comes threw the 2 vents but the pressure of the ac is not as good when the blower is off , any help would be greatly appreciated as I have already contact an ac repair man who could not help .
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Posted on Aug 06, 2011
Why will the ac on my Coleman Evcon C.A.M.II not come on when the fan will work and the heat will work?
The a/c component is is dependent on water access. I am guessing there is a problem with the water connection. The cooling aspect is simply the fan pushing the air past cold water. If everything else is working, take off the front and see if anything is wrong with the connection.
Elisa Jed ' http://www.greenhippoplumbing.com/services/
Jun 24, 2014 | Coleman Heating & Cooling
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
My blower wont shut off on my furnance
You can flip the switch in the fuse box, and that will shut it off
Mar 29, 2011 | Coleman Cable Double Pole 60a Circuit...
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Coleman Evcon no fan when in heating mode
Sounds like your flame proving device is not proving the flame. It is located on the last burner looks like a piece of thick wire sitting right beside the last burner. To Save you about 50 bucks service call take some steel wool and very gently clean the carbon that has built up on the surface of the device. Should only take 4 or 5 strokes.
Main blower will delay when in heating mode as to allow the heat chamber to build up enough heat to trigger the fan switch.
Nov 30, 2008 | Coleman Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
914 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
