Question about Lenoxx Electronics CD-149 Cassette/CD Boombox
1492 Need a new very small rubber drive belt, which runs from the electric motor pulley to the cassette drive pulley
Teac schematic
To replace a drive belt.
Before starting unplug from mains power source.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Stylus city
Jul 03, 2014 | Teac Audio Players & Recorders
The belt came off my record player how do i put it back on
take out the plate. there is a small wheel that turns and a big wheel below the plate. You should put the belt around them both and then put the plate on it (be careful, it's heavy).
Nov 16, 2011 | Audio Players & Recorders
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Cassette gets entangled, and does not play well
Cassette tape machines will occasional require maintenance after a certain period of usage. First open the cassette door and remove the tape and any broken tape remaining inside. Some models allow you to remove the cassette door allowing you to have better access to clean the unit. Next you will need to clean the capstan with alcohol and a Q-tip. The capstan is the metal post which the rubber wheel (pinch roller) pushes against to drive the tape across the tape head. Basically clean all the shiny metal parts including the tape head. Some of the tape residue may be difficult to clean, I use Tricloroetilene which has been regulated by the government, but you may try a product called Goof Off to clean the difficult parts, but it could eat the plastic and rubber parts so be careful. Next use a rubber cleaner on the pinch roller so you do not dry the rubber out, or it will become useless. The other problem is the cassette may be driven by a motor and belts. The belts may need to be replaced and the pulleys cleaned. For this you will need to disassemble the unit to access the belts but the cleaning of the pinch roller and capstan may fix your problem, if not you need to open it up to replace the main belt.
Jun 23, 2010 | Philips 3-Disc Changer FW320C Cassette/CD...
Drum doesn't spin or agitate. Only drains. Timer works.
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It doesn't agitate If your washer doesn't agitate, check these: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Jan 02, 2010 | General Electric WJRR4170GWW Top Load...
How to install belt on Maytag dryer
The motor pulley usually has grooves and the gooves must match on that pulley. The belt goes around the drum gooves down thur the tensioner and on the motor pulley.
Sep 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Drum/motor belt
you dont need to untension it, firstly place the belt on the small pulley on the motor then feed onto the main drum pulley gently turning it as you go, it may feel as though it wont go but it will as long as you have the right belt that is.
hope this helps
Jul 02, 2008 | Zanussi FC1200W Front Load Washer
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Sony PMC-DR50 Shelf System - need help installing new belts
look at the front side of a motor,you will see two screws,remove it,and that's it,change your belt.
Jan 21, 2007 | Sony PMC-DR50 Shelf System
Lenoxx Electronics CD-149 Cassette/CD Boombox Logo
57 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
Jonathon summesfield
Tony Mitri
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
