Question about U-Line ULine CLR2160S00 Echelon Series 15" Wide Undercounter BuiltIn Clear Ice Maker With Daily Ice Rate Up To 60 Lbs In Stainless Steel With Right Hand Hinge
Makes knocking sound every 15 minutes - U-Line ULine CLR2160S00 Echelon Series 15" Wide Undercounter BuiltIn Clear Ice Maker With Daily Ice Rate Up To 60 Lbs In Stainless Steel With Right Hand Hinge
What can cause knock sensor to get bad on 2007 ford edge
Well the knock sensor does not make any noise. It senses the vibration in the engine if there is a spark knock to let the computer know to slow down the spark timing.
You probably have a weak piston or lifter or rod bearing making the noise.
Jun 16, 2015 | 2007 Ford Edge SEL
Period loud tapping noise right side of dash 2010 Taurus
could be one of the doors in the heater box
May 28, 2012 | 2010 Ford Taurus
2001 BMW 325i problem: Car runs very rough, but no warning lights
Sounds like a fuel problem , have you changed the fuel filter in a while ? could be the knock sensor or the knock sensor module needs to be replaced.
Jul 28, 2009 | 2001 BMW 325
It is VERY loud on the spin cycle - both at 15 minutes (softer) and at the final 5 minutes (really loud).
hi,this sounds very much like the bearring have worn out,to check this open door and lift silver drum up and down if you feel a knocking noise then its your bearings .
Jul 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
MY ENGINE KNOCKS AFTER DRIVING A FEW MILES
you have a rod knocking in the engine
Feb 04, 2009 | 1985 Nissan 300ZX
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
U-Line ULine CLR2160S00 Echelon Series 15" Wide Undercounter BuiltIn Clear Ice Maker With Daily Ice Rate Up To 60 Lbs In Stainless Steel With Right Hand Hinge Logo
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
